Old 08-18-2019, 12:42 PM   #1
manitouguy
manitouguy's Avatar
Default Advice and comments on my early ford pls
Hi all – I had originally started this thread in the Model A section but was suggested that I also perhaps post here
I have recently acquired a modified 1928 Standard Coupe that was hot Rodded some back in the day - and as I am very new to early Fords I am trying to determine the year of many of the parts currently on it and learn more about the engine as well
Any advice or comments very much appreciated
Cheers Ron
https://www.fordbarn.com/forum/showt...=1#post1789263
manitouguy is offline   Reply With Quote
Old 08-18-2019, 01:20 PM   #2
alanwoodieman
Default Re: Advice and comments on my early ford pls
pictures really help start the ID process. engine - trans-rear axle-front axle
alanwoodieman is offline   Reply With Quote
Old 08-18-2019, 01:58 PM   #3
manitouguy
manitouguy's Avatar
Thanks Alan
There are links to the other threads w plenty of pictures - was trying to upload more here but ford barn wasn’t letting me or was some type of glitch
Old 08-18-2019, 02:06 PM   #4
supereal
supereal's Avatar
Find a good, reliable dealer in Model A Parts. For years we depended on Ron Cloat for his knowledge and array of parts. Sadly, Ron is gone, but a good place to research parts is the Ford "Green Bible) which covers all Ford parts from 1928 thru 1948. You can get a copy from C&G (800) 266-0470 as FPS -3633, $59.00. It is commonly called the "Green Book", It is a "must" for all old Ford enthusiasts.
supereal is offline   Reply With Quote
Old 08-18-2019, 03:58 PM   #5
JSeery
JSeery's Avatar
The photos.
The transmission number is early 1933 model production This is not correct, as pointed out below, I miscounted the digits!!!. The serial numbers were stamped into the transmissions and mated with an engine. When the assembly was installed in the vehicle that number was added to the frame and became the vehicle serial number. Because the engine is easy to separated from the transmission and were often rebuilt and switched out, the transmission number doesn't help much with the engine ID.
File Type: jpg 82C46B17-F72F-45E7-B86D-869348D17EE2.jpg (67.1 KB, 79 views)
File Type: jpg DA849AA4-975B-403F-99C1-843542A571ED.jpg (39.2 KB, 71 views)
File Type: jpg 1F5F1209-5A9B-45A1-A6F2-7C7E671B0169.jpg (99.3 KB, 67 views)
Old 08-18-2019, 05:12 PM   #6
Mike in AZ
Mike in AZ's Avatar
Transmission is 1935 according to VanPelt’s chart
Mike in AZ is offline   Reply With Quote
Old 08-18-2019, 05:17 PM   #7
DavidG
DavidG's Avatar
All '33 V8 engine numbers were six digits. Your transmission/engine number was used in July, 1935 production.
Old 08-18-2019, 05:35 PM   #8
manitouguy
manitouguy's Avatar
Thanks very much everyone - so it seems so far like a ‘35 trans with the ‘34 alum heads
Fan looks correct
Has a Holley 94 carb
Not sure yet what some of the other bits are ...
File Type: jpeg 253203EF-C5A7-4D99-A860-5B8316FB705B.jpeg (56.0 KB, 9 views)
Old 08-18-2019, 09:23 PM   #9
JSeery
JSeery's Avatar
Thanks Mike, I was using VanPelt's chart!! I miscounted the digits!!!
Old 08-18-2019, 09:39 PM   #10
cas3
looks like a 34 smooth intake manifold, and a 34 straight back fuel pump stand with the breather tube cut short...to me
Old 08-19-2019, 10:25 AM   #11
manitouguy
manitouguy's Avatar
Ok - so the cylinder heads are ‘-B’ so it appears they are the truck version
Why would they go with cast heads on trucks and aluminum on passenger cars?
File Type: jpeg 6D257518-E354-43EF-81B8-1E49509D9DF7.jpeg (71.7 KB, 5 views)
Old 08-21-2019, 07:55 PM   #12
manitouguy
manitouguy's Avatar
Hi all - another ‘ignorant’ question and thanks for your patience in advance
Here are photos of my front and rear wheels / brakes
I was told the wheels were ‘40 ford wheels with front brakes from ‘40s and rear brakes circa ‘55 that came with the Monarch rear end - I am wanting to learn more about brakes so I can understand how to check these and repair as needed
Embarrassing to ask this type of stuff – I am a partner in an architectural firm and know my trade inside and out but really out of my element when it comes to automobile mechanics – even the basics as you can clearly see - so starting to do a lot of reading on the basics but also asking here as I know many of you are deeply experienced in the ‘car craft’ and ford parts - so thank you for any input and advice
Do I see a nipple on both front and rear - juice brakes?
I seem to only be able to load one pic at a time ... so here is front wheel
File Type: jpg B7480364-2BA3-44DE-9BB1-B7DC50B6E3B4.jpg (27.3 KB, 25 views)
Old 08-21-2019, 07:59 PM   #13
manitouguy
manitouguy's Avatar
I’m working from an iPad and it doesn’t seem to like posting pics after the first one ... I’ll have to learn how to do this as well ....
Old 08-21-2019, 08:02 PM   #14
Tinker
Tinker's Avatar
Neat project. Running a 97strom would be closer to early year rodding (pre 39). but you have juice brakes.
Take pictures of the backing plates on the back and front. (the other side of the wheel you posted above)
Old 08-21-2019, 08:28 PM   #15
manitouguy
manitouguy's Avatar
Thanks Tinker - when I bought the engine with the car I was told it had a 97 carB on it ... either it was swapped out for the 94 or the seller was just mistaken - at some point in the future when I learn more about the proper parts I will get a Stromberg 97 and some other goodies for the engine too
Let’s see if I figured out the issue with posting pictures from the iPad – I think it was file size
File Type: jpg A3683C71-610A-48C8-A4D3-A677B6F15A80.jpg (64.7 KB, 40 views)
File Type: jpg 34334749-9F1C-47B3-98B5-7D1C7D27B27A.jpg (44.8 KB, 25 views)
File Type: jpg 8088EE66-DAB3-4AF9-A35D-852E41C79741.jpg (70.3 KB, 30 views)
Old 08-21-2019, 08:30 PM   #16
Tinker
Tinker's Avatar
Nothing wrong with a holley94. I do run strombergs though 36/38. (38 should have a chandler-groves "first year holley" but that's a whole different story).
Square spindle, Front backing plate looks like a f100... i think
Old 08-21-2019, 09:09 PM   #17
Tinker
Tinker's Avatar
They are both cast.
Trucks/big trucks always get the tougher less neat stuff. Years went longer also between changes.
Replacement heads for the early fords were available and usually in iron. also had a A - B suffix. If i am remember correctly.
Old 08-21-2019, 10:20 PM   #18
rich b
rich b's Avatar
Front brakes are '46-'48 Ford Lockheed. The rears are Bendix type.
rich b is offline   Reply With Quote
Old 08-22-2019, 10:01 PM   #19
manitouguy
manitouguy's Avatar
Thanks very much Rich - very interesting stuff!
