Old 07-29-2019, 04:49 PM   #1
1930deluxe
Default Coolant Filter
What does the coolant filter go and what does it look like?
1930deluxe is offline   Reply With Quote
Old 07-29-2019, 05:12 PM   #2
Russ/40
Russ/40's Avatar
Default Re: Coolant Filter
Depends, I think as many people make their own as purchase one. I made mine out of a fine stainless screen inserted at the top inlet to the radiator in the hose. I shaped it into a conical shape.
Russ/40 is offline   Reply With Quote
Old 07-29-2019, 05:36 PM   #3
30 Closed Cab PU
A frequently used/mentioned is the Gano filter, all coolant filters should be placed in the Upper Hose to keep rust/scale/junk out of the radiator.
https://ganofilters.com/
If you do a search on Coolant Filters, lots of info
30 Closed Cab PU is offline   Reply With Quote
Old 07-29-2019, 08:45 PM   #4
jax55
jax55's Avatar
I used a nylon sock at the upper radiator/ hose connection.
jax55 is offline   Reply With Quote
Old 07-29-2019, 09:07 PM   #5
Brian SATX
Brian SATX's Avatar
I use the Gano and like it. You can see if it is clogged up.
Brian SATX
Brian SATX is offline   Reply With Quote
