Old 04-01-2019, 10:05 PM   #1
zoegrant
zoegrant's Avatar
Default Pcv on 1955 272 engine
Guys...I am thinking about removing the road draft tube and installing a PCV setup on my 55 sedan with a 272 engine.
After a drive my garage always smells of oil.
Any recommendations on which PCV valve to use and how best to hook it up ?
zoegrant is offline   Reply With Quote
Old 04-01-2019, 10:15 PM   #2
miker98038
miker98038's Avatar
Default Re: Pcv on 1955 272 engine
Long current discussion here. Read Ted Eaton’s remarks, and the whole thread.
http://forums.y-blocksforever.com/Topic144832.aspx
If you’re not a member, you might think about joining over there also.
miker98038 is offline   Reply With Quote
Old 04-02-2019, 12:12 PM   #3
zoegrant
zoegrant's Avatar
MIKER98038...…..thank you for the Y-block forever web site info...regards, John
Old 04-02-2019, 10:09 PM   #4
Daves55Sedan
Daves55Sedan's Avatar
You can laugh if you want to, but I always save old socks that have developed a hole in the heel and I just cut off the top part of the sock and slip it over the road draft tube so that the toe end is about one inch below the bottom of the tube. The sock is held in place with a zip tie around the tube
The sock catches what little oil drippage there might be and also seems to filter out the worst of the smoke. I change the sock as needed when I happen to be doing an oil change as they do get pretty nasty over time.
Daves55Sedan is offline   Reply With Quote
Old 04-06-2019, 03:47 PM   #5
reddog565
Hi, I'm having the same issue on my 272, it already has a PCV valve. But, I think it's allowing oil to get sucked into the manifold and it's burning it. The valve number is CV-726C. Very rare and expensive. Have you found a replacement valve that works? If so,I would like to get the part number, if you could help me out.
Thanks.
reddog565 is offline   Reply With Quote
Old 04-06-2019, 04:55 PM   #6
Alaska Jim
Alaska Jim's Avatar
reddog565, see post #2 by miker98038 in this thread
Alaska Jim is offline   Reply With Quote
