Old 04-01-2019, 04:40 PM   #1
JMFL36
JMFL36's Avatar
Default 54 Merc light switch removal
Anyone have experience removing the light switch from a 54 Merc? Shop manual doesn't cover it. I can't figure out how to remove the rod from the switch or the knob from the rod so I can back the switch out of its cubby in the back of the dash.
Document your car with CollectorCarCompanion
JMFL36 is offline   Reply With Quote
Old 04-01-2019, 08:04 PM   #2
paul2748
paul2748's Avatar
Default Re: 54 Merc light switch removal
Not familiar with a Merc switch (totally different from a Ford), but take a look under the knob and see if there is a set screw holding it. The chrome bezel may just twist off once the knob is removed.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-02-2019, 02:31 AM   #3
JeffB2
JeffB2's Avatar
Look at the picture here:https://www.ebay.com/itm/Ford-Mercur...del%3AMonterey The Merc has a much longer shaft but the switch works the same as a Ford you have to push in that spring loaded button and then pull the shaft to remove it.
JeffB2 is offline   Reply With Quote
Old 04-02-2019, 09:04 AM   #4
54vicky
54vicky's Avatar
as Jeff said you need to push that little button and pull.I have found it helped to push the button in then slowly pull the knob out you will feel the release as it engages it may take a few tries until you feel it then keep the button pushed in while pulling.then when you have the rod out it looks as if there is a nut looking piece that holds the switch in. actuality the nut is a bolt for lack of a better word turn it counter clockwise it will undo allowing switch to be removed. it will help to support switch while doing this.goes without saying disconnect the battery firstif original wiring be aware that it will be very brittle the wire itself should be okay but the insulation will fall apart.
54vicky is offline   Reply With Quote
Old 04-02-2019, 12:20 PM   #5
JMFL36
JMFL36's Avatar
Ah, got it. That little button is a bitch to get at, but once I was able to get my fat fingers in there so I could push in the spring-loaded button the rod came right out. Thanks guys.
