Old 02-11-2019, 07:47 PM   #1
Jwawhite
Jwawhite's Avatar
Default A Pillar Wind Noise Water Leaks
The weatherstrip appears to be incorrect for this model of car. It's not wide enough to cover the lip on the A Pillar.
Take a look at the attached photos, I've seen two other model wagons with same issue. I took a business card and could pass it from the out side of the vehicle past the A Pillar.
The doors do need a better adj but the lines of the door are close to adequate.
Same problem? What did you do? Add a wider strip in this area? If you take into account the line of the door to body, perhaps a quarter inch wider, plus? would quiet things down and stop the water leak.
I'll try, anyone with an original photo,stock car, of this area of a Wagon?
Jwawhite is offline   Reply With Quote
