#7 | ||
The only way I could ever correct this problem was too remove the door pillar latch to be able to align the door so it sits correctly in the door opening. Lift on the rear of the door to see if the hinges are good and go from there. You may have to persuade the glass opening frame to seal more tightly against the jamb. There is an adjustment fixture shown in the manual that will give you an idea of how to go about it with blocks and a lever (2X4). Just don't go ape on it.When you are satisfied with positioning, install the latch. Yours had some damage. Remember the latch pillar failure? It may have been in a collision and not brought back to spec. https://www.kent-automotive.com/kent...tock/P46505.ka
***** "Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'." ― Charlene Darling (Daughter of Briscoe Darling) |
