Old 01-21-2019, 10:22 AM   #1
flathead 53
Default T-170 od trans to a 53 f-100
Any one put A t-170 OD transmission in a 53 f-100 with a flathead? If so what were the problems in doing the swap? thanks, I have A 1985 T-170 out of A f-150 .thinking about putting it behind my 53 f-100.
flathead 53 is offline   Reply With Quote
Old 01-21-2019, 12:36 PM   #2
blucar
blucar's Avatar
Default Re: T-170 od trans to a 53 f-100
I doubt very much that someone is making a bell-housing adapter to to fit the T-170 OD to the 8BA style of engine.
The 1951 and later F-1 V8 trucks came with a three on tree OD option, I think it was a Borg-Warner.. The '51 and later OD trans for the cars and trucks should be the same unit.
Bill.... 36 5 win cpe
Old 01-21-2019, 01:31 PM   #3
skidmarks
skidmarks's Avatar
Easiest way is to use the stamped steel shoe box bellhousing but you will need to make clutch linkage and a transmission mount.
If your crafty it's pretty straight foward
skidmarks is offline   Reply With Quote
Old 01-21-2019, 01:53 PM   #4
V8 Bob
V8 Bob's Avatar
The '53 truck bell has side mounts, along with a centered front engine mount. A lot of work would be required to adapt a car bell.
V8 Bob is offline   Reply With Quote
Old 01-21-2019, 01:57 PM   #5
skidmarks
skidmarks's Avatar
Like I said if your crafty. The stamped steel shoe box bell you can easily weld to it.
The 53 truck bell is all by itself (one year ) and too deep ( like a y block truck bellhousing)for the t170 input shaft.
Crafty is the key word
Old 01-22-2019, 08:59 AM   #6
Ol' Ron
Ol' Ron's Avatar
The steel bell housing is what I use along with the stock linkage. However the 53 is a different beast all together, I expect it could be done, BUT????
