Any one put A t-170 OD transmission in a 53 f-100 with a flathead? If so what were the problems in doing the swap? thanks, I have A 1985 T-170 out of A f-150 .thinking about putting it behind my 53 f-100.
I doubt very much that someone is making a bell-housing adapter to to fit the T-170 OD to the 8BA style of engine.
The 1951 and later F-1 V8 trucks came with a three on tree OD option, I think it was a Borg-Warner.. The '51 and later OD trans for the cars and trucks should be the same unit.
Bill.... 36 5 win cpe |
Easiest way is to use the stamped steel shoe box bellhousing but you will need to make clutch linkage and a transmission mount.
If your crafty it's pretty straight foward |
#4 | |
The '53 truck bell has side mounts, along with a centered front engine mount. A lot of work would be required to adapt a car bell. |
#5 | |
The 53 truck bell is all by itself (one year ) and too deep ( like a y block truck bellhousing)for the t170 input shaft. Crafty is the key word |
