Old 09-20-2018, 11:03 AM   #1
37don
Question Drake gas tanks
Has Drake fixed the size of the gas tank figment problem with their early tanks?
I plan to replace the tank in my early 37 4dr with the screw in neck.
Thanks in advance, regards, Don
37don is offline   Reply With Quote
Old 09-20-2018, 12:16 PM   #2
RalphM
RalphM's Avatar
Default Re: Drake gas tanks
I hope so, I have yet to install my new tank in my 35.
I’m still working on getting the tank neck out of the old one without damage.
RalphM is offline   Reply With Quote
Old 09-20-2018, 12:56 PM   #3
35fordtn
35fordtn's Avatar
I never had a problem with fitments on the 1936 and 37 tanks.. I have installed three of them. It's the later 38-40 tanks that give the trouble.. Even with that said thank can be installed
35fordtn is offline   Reply With Quote
Old 09-20-2018, 02:12 PM   #4
hotrodart
hotrodart's Avatar
I put a SS Drake tank in my '40 a couple of years ago......it fit perfectly.......about 2-1/2 hours for the whole job, on my back in my shop. Would easily recommend that tank.
hotrodart is offline   Reply With Quote
Old 09-20-2018, 03:39 PM   #5
51504bat
51504bat's Avatar
Drake tank for my '39 p/u fit fine but I did take the bed off to install it.
Old 09-20-2018, 07:21 PM   #6
deuce5wndw
deuce5wndw's Avatar
Installed a Drake tank on my 40 coupe with no problems
deuce5wndw is offline   Reply With Quote
Old 09-20-2018, 08:14 PM   #7
Dave Castle
Dave Castle's Avatar
Recently returned a Drake tank that would NOT fit correctly in a 40 pu. Also the drake sending unit would not fit correctly in their own tank !!!!
Dave Castle is offline   Reply With Quote
Old 09-21-2018, 05:46 AM   #8
ford nut
ford nut's Avatar
whats the trick to that?
ford nut is offline   Reply With Quote
Old 09-21-2018, 08:42 AM   #9
RalphM
RalphM's Avatar
Tell me, and we will both know
I bought a spanner wrench and can get it on the holes, but not enough leverage to turn it.
I’m thinking I have to remove the fender so that I can fit a cheater pipe to the wrench. My other thought is if I can torch the neck off the tank first and then deal with it in the bench vise.
No worries about the flames, tank has rust holes as big as my fist in bottom.
Old 09-21-2018, 10:29 PM   #10
uncle buck
uncle buck's Avatar
I think you are on track with that thought , although it might just be a better idea to just order a new Drake filler neck
uncle buck is offline   Reply With Quote
