#1 |
Some posts questioned the rear cross member hole cover. Attached is a photo of what appears to be an after market metal cover. The holes are also in the pan for the fabric cover straps.
#2 |
That takes a few pressings to make. Fords way was much cheaper using left over upholstery material.
Model A Ford Club of New Jersey http://www.mafcnj.org Model A Pick Up Owners and Enthusiasts http://www.fordbarn.com/forum/group.php?groupid=5 |
#3 |
My original s/w has a fabric cover. Hopefully the picture is attached
#4 |
Somewhat off topic but...
I recently removed the fabric crossmember cover on a '31 Slant Windshield to replace a rear spring u-bolt because of a stripped thread. It would have been ugly if it had a riveted cover! Good Day! Last edited by Dave in MN; 08-24-2018 at 02:45 PM. |
#5 |
duke if you install a metal cover over the hole, your seat spring bottom will be ridding right on it. installing a fabric one is easy.
#6 |
