Old 06-25-2018, 07:52 PM   #1
swedishsteel
Default Stromberg 97 jet question
Discovered one jet was a thread or two from seating. How would that, if at all, affect how the motor would run? Would it run lean on low vacuum situations? Thanks for any ideas. Rod
swedishsteel is offline   Reply With Quote
Old 06-25-2018, 08:42 PM   #2
scicala
scicala's Avatar
Default Re: Stromberg 97 jet question
If it was just backed off a thread or two, it's probably not enough to block off the supply of fuel from the bowl. It might leak a little fuel around the threads when there is suction from the emulsion tubes, but chances are you may not even notice any thing wrong with the performance.
Also, the jets hold the emulsion tubes in place (seat on them), so possible the tube came down as far as the loose jet was.
Sal
