#1 |
On several occasions my starter has kept turning after the engine starts and bendix releases. What could be causing this? I'm still on the original 6 volt system.
#2 |
Anybody ever have this problem where the starter motor keeps running after the engine starts?
#3 |
Starter switch is sticking, remove and clean the contacts!
#4 |
Sounds right. I'll check it out. Thanks!
#5 |
Check the battery as well. A weak battery can cause sticking contacts as well.
#6 |
#7 |
Thanks for all the input!
#8 |
ALWAYS push the starter FIRM & HARD, to lessen the chance of ARCING & "welding" the contacts together. ADD this to your FULL Sheet list of "HOW TO START YOUR DAMNED MODEL A"----"Maybe" thet's why CROOKS didn't use Model As????
Bill Stomper
#9 |
Once you have the starter switch off, check to see if the bronze contact strip is not catching on the cardboard insulation on the sides.
