Old 05-15-2018, 07:21 PM   #1
str8axle63
str8axle63's Avatar
Default electric fuel pump for 6 volt v8 flathead positive ground
My fuel pump died, bought a new one and still Not pumping. I checked the line and it is not clogged. I'm considering an electric fuel pump. I see summit has a Airtex 6v pump.
My question is will work on a positive ground system? Anyone have any experience with this?
Thanks for your help
str8axle63 is offline   Reply With Quote
Old 05-15-2018, 08:22 PM   #2
fottyjs
Default Re: electric fuel pump for 6 volt v8 flathead positive ground
I have the Airtex 3 psi model on 2 vehicles and they perform well...I use them for starting after the cars have been sitting for a while.....
fottyjs is offline   Reply With Quote
Old 05-15-2018, 08:39 PM   #3
JSeery
JSeery's Avatar
I'm not sure if polarity matters on the pump, my guess would be it doesn't. But no reason to not wire it up with the correct polarity, the (+) terminal on the pump would connect to ground and the (-) terminal would connect to power. That should keep the electrons happy.
Old 05-16-2018, 05:36 AM   #4
dwick01
dwick01's Avatar
Works perfectly on my '47 6v with (+) terminal on pump connected to ground and (-) to power.
dwick01 is offline   Reply With Quote
Old 05-16-2018, 07:21 AM   #5
slowforty
Rock Auto has Airtex for a reasonable price.
slowforty is offline   Reply With Quote
Old 05-16-2018, 07:26 AM   #6
Greg58
Greg58's Avatar
I replaced a bad pump on my 50 a couple of months ago for the same reason, it seems that the diaphragm stretches more than OEM or the arm travel is not as well designed on after market pumps. A friend that has worked a lot on flatheads said to add a piece of leather in the cup of the pump arm, said it would improve pump action.
Greg
Greg58 is offline   Reply With Quote
Old 05-16-2018, 08:16 AM   #7
RKS.PA
RKS.PA's Avatar
The Airtex pumps do have a life, albeit reasonable. J. Seery is correct. The 6 volt pumps will work on either a positive or negative ground and his explanation of how to wire it is spot on.
Dick.
RKS.PA is offline   Reply With Quote
Old 05-16-2018, 07:11 PM   #8
FireEngineMike
FireEngineMike's Avatar
Send the pump to charlie ny for a rebuild with an ethanol safe diaphragm. No need to mess with half-assed fixes.
FireEngineMike is offline   Reply With Quote
Old 05-16-2018, 08:22 PM   #9
str8axle63
str8axle63's Avatar
Thx guys,
Ordered airtex from summit
Old 05-17-2018, 12:04 AM   #10
Drbrown
Drbrown's Avatar
2x (1) Airtex, and (2) Charlie NY rebuild.
Drbrown is offline   Reply With Quote
Old 05-17-2018, 05:29 AM   #11
mike42
mike42's Avatar
You won't be disappointed with the Airtex. Good little unit !
Mike
mike42 is offline   Reply With Quote
Old 05-17-2018, 01:40 PM   #12
Greg58
Greg58's Avatar
Which idea are you talking about? A electric pump is all that will work on some applications, a lot of people have installed a electric to assist on hot starts. The leather I mentioned was to test the pump action, not a repair. If the leather makes the pump work the arm is not designed correctly as I stated. Everyone has their own ideas how to make things work.
Greg
Old 05-17-2018, 02:46 PM   #13
Cecil/WV
Cecil/WV's Avatar
E8902 is the correct Airtex pump for these Fords.
Cecil/WV is offline   Reply With Quote
Old 05-17-2018, 05:16 PM   #14
jerdan
jerdan's Avatar
I have the airtex on my 6 volt positive ground. Works great.
jerdan is offline   Reply With Quote
Old 05-17-2018, 05:53 PM   #15
Jack E/NJ
Jack E/NJ's Avatar
Sadly, my Airtex experience hasn't been as good. Pressure-side fuel leaks around what appears to be a pressed-in female pipe fitting on a new unit. Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 05-17-2018, 07:31 PM   #16
Graeme / New Zealand
Graeme / New Zealand's Avatar
I found rock auto by mistake..their prices are very good for the products they sell and delivery was quick, even down here to NZ.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
