My fuel pump died, bought a new one and still Not pumping. I checked the line and it is not clogged. I'm considering an electric fuel pump. I see summit has a Airtex 6v pump.
My question is will work on a positive ground system? Anyone have any experience with this? Thanks for your help |
I have the Airtex 3 psi model on 2 vehicles and they perform well...I use them for starting after the cars have been sitting for a while.....
I'm not sure if polarity matters on the pump, my guess would be it doesn't. But no reason to not wire it up with the correct polarity, the (+) terminal on the pump would connect to ground and the (-) terminal would connect to power. That should keep the electrons happy.
Works perfectly on my '47 6v with (+) terminal on pump connected to ground and (-) to power.
Rock Auto has Airtex for a reasonable price.
Greg |
The Airtex pumps do have a life, albeit reasonable. J. Seery is correct. The 6 volt pumps will work on either a positive or negative ground and his explanation of how to wire it is spot on.
Dick. |
Send the pump to charlie ny for a rebuild with an ethanol safe diaphragm. No need to mess with half-assed fixes.
Thx guys,
Ordered airtex from summit |
2x (1) Airtex, and (2) Charlie NY rebuild.
You won't be disappointed with the Airtex. Good little unit !
Mike |
Which idea are you talking about? A electric pump is all that will work on some applications, a lot of people have installed a electric to assist on hot starts. The leather I mentioned was to test the pump action, not a repair. If the leather makes the pump work the arm is not designed correctly as I stated. Everyone has their own ideas how to make things work.
Greg |
#13 |
E8902 is the correct Airtex pump for these Fords.
#14 |
I have the airtex on my 6 volt positive ground. Works great.
#15 |
Sadly, my Airtex experience hasn't been as good. Pressure-side fuel leaks around what appears to be a pressed-in female pipe fitting on a new unit. Jack E/NJ
#16 |
I found rock auto by mistake..their prices are very good for the products they sell and delivery was quick, even down here to NZ.
GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
