Old 04-28-2018, 08:43 AM   #1
Brendan
Brendan's Avatar
Default 64 F-100 6 to Y-block
is it a bolt in job? i know that exhaust needs changing, what about other stuff?
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 04-28-2018, 10:32 AM   #2
Ole Don
Ole Don's Avatar
Default Re: 64 F-100 6 to Y-block
Maybe ask in a pickup forum.
Ole Don is offline   Reply With Quote
Old 04-29-2018, 06:27 AM   #3
ponymare
You will need everything a V8 truck would have come with, bell housing, flywheel, clutch, clutch linkage, and front mount for that year truck.
ponymare is offline   Reply With Quote
Old 04-29-2018, 11:18 AM   #4
rotorwrench
rotorwrench's Avatar
The radiator & mounting is likely different too. If you find a donor vehicle of the same vintage then that might simplify things.
Old 04-30-2018, 09:30 AM   #5
blucar
blucar's Avatar
The application of a V8 Y-block in lieu of a 6 cylinder will require the correct V8 bell-housing to fit the trans in the truck, 3 spd vs 4spd. The front mount for the V8 is a large steel stamping that bolts to the front timing case. Pretty simple swap if you have the right mounting components.
If you want to PM me I can send you some pix of the mount for a Y-block, I have a '64 Y-block that I removed from a '64 F100...
Bill.... 36 5 win cpe
