Old 04-10-2018, 01:46 AM   #1
Phil Gillespie
Phil Gillespie's Avatar
Default Exhaust Mounted Engine Stand
Have just got one of these engine stands. But need to make an adaptor for a side mount at exhaust. 91 A block. Somewhere I recall reading that the bracket is angled at 45 degrees to horizontal pivot on stand.
Am I right.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 04-10-2018, 01:56 AM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: Exhaust Mounted Engine Stand
Yep you got it right.
Piece of flatiron use a exhaust manifold as drill pattern.
Old 04-10-2018, 05:13 AM   #3
JSeery
JSeery's Avatar
One way to do it is with a section of angle and a flat plate. Here are some examples.
Old 04-10-2018, 11:29 AM   #4
Phil Gillespie
Thanks J Serry. Thats another option with the angle iron for added strength.
Phil NZ
Old 04-11-2018, 04:24 AM   #5
35ragtop
35ragtop's Avatar
Or if you like your woodwork, you could build one of these, as one of our enterprising 84 year old members did. It worked perfectly and so far he has assembled two engines on it. He does admit that the cutouts for the exhausts were not necessary .
What you can achieve with a bit of ingenuity!
35ragtop is offline   Reply With Quote
Old 04-11-2018, 07:07 AM   #6
JSeery
JSeery's Avatar
I fab'd one so that it would bolt to my existing plate on the stand vs to a piece of tubing.
Old 04-11-2018, 12:18 PM   #7
early46
Here is one I built, works very well
early46 is offline   Reply With Quote
Old 04-11-2018, 04:01 PM   #8
Phil Gillespie
I really appreciate all the various ideas on this item and they are all good info.
The adaptor to the original which bolts on I'm liking.
Phil NZ
Old 04-12-2018, 09:17 PM   #9
Capn John
Capn John's Avatar
https://www.stumpysfabworks.com/stor..._Products.html
Capn John is offline   Reply With Quote
Old 04-13-2018, 05:42 AM   #10
Phil Gillespie
Originally Posted by Capn John View Post
Have similar being made up here in NZ. Problem as with most good price locally in US but time its shipped to NZ could be extra $70 to $90 .
Phil NZ
