Old 02-27-2018, 06:33 PM   #1
joshhirst13
Default Getting my 1931 Model A Coupe go start
Hey guys,
I just picked up my Model A Coupe a few weeks ago & Im having issues getting it started. I can't even get it to turn over or make a noise. It's got a freshly charged battery on it, I removed the positive/ground cable & used a wire brush to clean up the contact. I also cleaned up the contact under the starter switch & negative battery cable connection to the starter switch. I turn on the ignition switch, push the clutch in, trans in neutral, push the starter switch pedal & I get absolutely nothing. The previous owner installed blinkers, which I get power to, as well as power to the headlights & tail lights. I'm not sure where to go from there. Maybe new battery cables? Maybe new ignition coil? I'm pretty pathetic when it comes to electrical stuff. I have a voltage tester, just don't know what to check. Any suggestions would help.
Thanks
joshhirst13 is offline   Reply With Quote
