Old 02-25-2018, 06:15 PM   #1
Deuce Bob
Deuce Bob's Avatar
Default 1936 Ford steering gear identification?
Hello Can someone post a picture or tell me how to identify a steering gear I have. I think it is a 1936 Ford. thanks Bob
Deuce Bob is offline   Reply With Quote
Old 02-25-2018, 06:58 PM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: 1936 Ford steering gear identification?
I may be wrong but I think 36 was the only year with needle bearings on the sector from the factory instead of a bushing. I know that is not much help. When you say "steering gear" do you mean the whole thing with a mast jacket or something apart or only the worm or sector? You might post pictures.
Old 02-26-2018, 10:56 AM   #3
Andy
There were only two cross steer boxes with bolt in sector housings. 35&36. The 36 housing is bigger to accomadate the needle bearings.
I believe the 36 box is a bigger ratio. It would be 17 to 1. The 35 was 15 to 1. It would have 3.75 turns total. The 36 would have 4.25 turns.
Andy is offline   Reply With Quote
Old 02-26-2018, 11:43 AM   #4
Don Rogers
Don Rogers's Avatar
How about a photo of what you have? You may not have a 35 or 36.
Don Rogers is offline   Reply With Quote
Old 02-26-2018, 09:16 PM   #5
JM 35 Sedan
JM 35 Sedan's Avatar
The first picture is a 36 steering box. The other pictures are comparing a 36 steering box to a 38-39 steering box.
File Type: jpg 36 steering column box, shaft, & tube.jpg (112.0 KB, 48 views)
John
