Old 01-09-2018, 12:27 PM   #1
Bud
Bud's Avatar
Default Pictures of YOUR transmission rebuild stand.
Do you folks use a stand to rebuild your transmission? If so I would request you post a picture and a comment or two. I am thinking of building one and would like to see the "state of the art". Thanks in advance to everyone willing to share.
Bud is offline   Reply With Quote
Old 01-09-2018, 12:41 PM   #2
George/Maine
George/Maine's Avatar
Default Re: Pictures of YOUR transmission rebuild stand.
You don't want to over think this, in the day a kitchen table will do.
George/Maine is offline   Reply With Quote
Old 01-09-2018, 12:47 PM   #3
Mart
Mart's Avatar
I have used a wide 5 wheel to nestle the trans in, on top of the bench.
Mart.
Mart is online now   Reply With Quote
Old 01-09-2018, 01:01 PM   #4
svm99
Here's the style I manufacture and use. They will fit all Ford 3spd trans cases from '32 to '48..................top shift, side shift, and V8 60.
Paul J.
svm99 is offline   Reply With Quote
Old 01-09-2018, 01:05 PM   #5
flatheadmurre
flatheadmurre's Avatar
Pipethread in the bottomplug of the case then either in your benchwise or make a floormount.
Old 01-09-2018, 01:09 PM   #6
Kube
Super Moderator
Kube's Avatar
Mine looks exactly like my work bench - because it is my work bench.
Old 01-09-2018, 01:30 PM   #7
Ed Pitts
Ed Pitts's Avatar
Here is the pipe with a plywood floor mount. Pipe screws into the bottom drain.
Ed
Ed Pitts is offline   Reply With Quote
Old 01-09-2018, 01:41 PM   #8
Tim Ayers
This what I use. I tapped a piece of box steel and then mount that in the vice. Works well for me.
I've also fabbed up cradles out of the bed frame angle iron. Works great.
Old 01-09-2018, 02:38 PM   #9
JM 35 Sedan
JM 35 Sedan's Avatar
Here's one I saw somewhere and copied the pictures to my files for future reference. It may be Vern Tadell's idea/design, can't remember. I've also made some legs using 3/4" angle iron that bolted to the holes in the front bell and kept the case sitting open end up on my work bench. That worked well, but no pictures available, just have to use your imagination
John
Old 01-09-2018, 02:51 PM   #10
Seth Swoboda
Seth Swoboda's Avatar
This made me laugh. Mine is the same, my work bench.
Seth Swoboda is offline   Reply With Quote
Old 01-09-2018, 03:04 PM   #11
B-O-B
B-O-B's Avatar
The last time I did one was on the floor of the barn.
B-O-B is offline   Reply With Quote
Old 01-09-2018, 03:09 PM   #12
JM 35 Sedan
Did one what??
John
Old 01-09-2018, 03:15 PM   #13
B-O-B
B-O-B's Avatar
Naw, that was in the hay loft a sleep over that night. Thanks for the reminder tho!!!
Old 01-09-2018, 03:18 PM   #14
Ken/Alabama
Ken/Alabama's Avatar
Here's what I use.
Ken/Alabama is offline   Reply With Quote
Old 01-09-2018, 03:52 PM   #15
40Pickup
40Pickup's Avatar
Yes, I know a little overkill!
It's about the creation ...... can not help it.
Jorgen
40Pickup is offline   Reply With Quote
Old 01-09-2018, 04:05 PM   #16
flatheadmurre
Rivets...have to love it !
Old 01-09-2018, 04:11 PM   #17
Gary-UK
Gary-UK's Avatar
Just a simple box section frame to stop it rolling around, can be clamped in vice too.
File Type: jpg 2ED33788-A9F4-427F-9101-4D4783DD3E84.jpg (62.8 KB, 156 views)
Gary-UK is offline   Reply With Quote
Old 01-09-2018, 04:11 PM   #18
DavidG
DavidG's Avatar
Mine bears a remarkable resemblance to the floor (with some added padding). When they're done I put them on a small padded moving dolly from Harbor Freight.
Old 01-09-2018, 05:52 PM   #19
Charlie ny
I use a steel pipe plug ( drain plug size )with a chuck of 5/16 flat stock welded to the square. The plug goes in the bottom of the case and the flat stock goes in my vise.
Charlie ny
Charlie ny is offline   Reply With Quote
Old 01-09-2018, 06:27 PM   #20
flatford39
That's the one I use instead of just a piece of pipe in the drain hole. It allows you to move the trans around with out loosening the vice. Worked great.
flatford39 is offline   Reply With Quote
