#1 |
Just thought of this yesterday and thought it might help folks make the messy job of filling your trans. and diff. with gear oil, etc. Also steering box with corn head grease, etc. Works great. You can"squirt" the gun at any angle.
1.Remove the plastic end cap plunger from empty caulking tube and clean out the insides of both nice and clean. I used gasolene. 2. Cut spout so it has a 3/8 in. ID. 3. Screw in 3/8 dia. bolt just a few threads to prevent any leaking. 4. Pour gear oil into cleaned out caulking gun. It holds 15 oz. 5.Insert plastic plunger. 6. Insert cartridge in caulking gun, unscrew bolt and pull the trigger to fill. 7. Remove plastic plunger through the spout with 1/8 dia. rod, wooden dowel or long thin screwdriver. Empty can was used to support cartridge. Use different cartridges for specific lubricants. Last edited by 19Fordy; 01-06-2018 at 10:01 AM. |
#2 |
Brilliant and way less messy, and not near as wasteful, than other ideas I have tried. Well done, sir!
#3 |
I particularly appreciate this kind of thread. 19Fordy gives us a good solution to a problem with pictures and narrative, so that his good idea makes sense to the densest of us.
Thanks for the information. |
#4 |
Great idea!!!.....but I see no good use for STP oil treatment.
..."they are only original once" |
#5 |
Why reinvent the wheel. I buy a gallon container of gear oil that has a pump and hose/nozzle with it to fit in the filler hole. |
#6 |
https://www.amazon.com/Custom-Access...9BYWYB97GAH2A4
#7 |
Please share more info? Brand and where you purchase?
Thanks Andy 1952 F1 |
#8 |
I didn't know there was a pump available. I hope it works good as I have never found pumps like those to be long lasting. Mine always break and never reach the bottom of the bottle. Plus, caulking tube is cheap.
#9 |
#10 |
I posted a URL with the Amazon Link. Click on it to go there. The one I bought is a 36671 Pennzoil Fluid Transfer Pump. I only used it once so far, so I can't say how long it might last. It is all plastic, so not all that sturdy, but you are only pumping a little gear oil.
#11 |
Years ago, I bought a suction/pump device that looks like the caulking gun set up from NAPA. It was probably used in the old days to suck oil out of the oil filter canister as well as filling trans and difs. I would think that they would still be available.
#12 | |
A lot of good ideas presented here on this thread.....all good in my opinion.
#13 |
I make a 50/50 solution of synthetic gear oil (90wt) and synthetic grease to put into my steering box, u-joint to put it in I use a air powered grease gun--less messy and works good. I like the caulk tube idea, will give it a try
#14 |
..."they are only original once" Last edited by Bertha; 01-05-2018 at 07:30 PM. |
#15 |
I like this idea.
I have one of the pictured pumps and as stated above, it doesn't reach down far enough into the container.
Matt 24:36-41 |
#16 |
Can't wait to try the caulking gun trick. And I have been known to add some stp as well. Thick is good in a crash-box. Thank you for the idea!
#17 |
I got one of these at Advance Auto Parts
http://hardwareonlinestore.com/index...hg7f5djqitnahs
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
#18 |
Great idea 19Fordy. Thanks for sharing. I am going to make one and give it go.
#19 |
Anyone know anything about this gallon container? Brand & where to buy?
#20 | |
https://www.napaonline.com/en/p/SLRSL24239 Gear oil pump; https://www.google.com/search?tbm=is...=1515248440665 |
