Old 12-06-2017, 03:23 PM   #1
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default 49-53 Load A Matic problem
Just another review of a typical 49-53 Problem. The primary lead wire runs under the point plate. Over time the plate rotates back and forth wearing the lead wire insulation off . This one ran fine but died when vac was applied t diaphrahm... Pain in the butt to replace and should be replaced with correct Ford lead wire . proper resistance and end hook ups...
AND dont use tape or shrink wrap as it will restrict advance..........
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 12-06-2017, 05:05 PM   #2
oldford2
oldford2's Avatar
Default Re: 49-53 Load A Matic problem
As Bubba says...replace with the correct FLEXIBLE lead. Don't try using shrink tubing since it will restrict the plate movement. Ask me how I know
oldford2 is offline   Reply With Quote
Old 12-06-2017, 07:10 PM   #3
40 Deluxe
What is the proper resistance of this wire, and are OEM ones available?
Old 12-06-2017, 07:49 PM   #4
tubman
tubman's Avatar
You are referring to the wire inside the distributor, aren't you? It's not exactly clear.
Old 12-06-2017, 07:56 PM   #5
BUBBAS IGNITION
Yes there are some new ol stock leads out there. I have a few but not for sale , only for use on a rebuild...
[email protected]
Old 12-06-2017, 07:56 PM   #6
BUBBAS IGNITION
Yes under the breaker plate......
[email protected]
Old 12-06-2017, 09:05 PM   #7
scicala
scicala's Avatar
I don't think there would be any resistance in this wire. Any resistors, if any would be to the coil +side.
Sal
Old 12-07-2017, 09:52 AM   #8
BUBBAS IGNITION
Sal
The primary ignition circuit is a special circuit designed to handle the voltages in the circuit....
Example :
In a 12 volt circuit (easier for me to explain) the battery voltage is 12.2 volts after sitting overnight. We have a 1.5 ohm coil and a 1.5 ohm resistor , when the engine starts each resistor drops approx 6 volts allowing a small voltage to cross the ignition contacts. ( amps is another story as amps are constant in a series circuit) . Thats cool until the alternator starts to charge and we then have to deal with 14.6 volts. Now the resistors heat up and offer slightly more resistance but the voltage at the contacts now is 2-3 volts. The primary lead is a finely stranded wire designed to drop this excess voltage to as close to zero as we can get...
Heres a couple examples laying on my desk from a Mustang and the NAPA buyers guide showing these leads . Offen times this lead changed every model year in a effort to make the points last longer . In our chevy conversion we buy a new lead for every unit from Standard Motor products.
The typical "hot rod guy" cuts this lead and replaces with new 12-14 gauge lead wire and upsets the entire balance of the system!!! Thinking this is the thing to do !!!
[email protected]
Old 12-07-2017, 10:05 AM   #9
BUBBAS IGNITION
duplicate
[email protected]
Old 12-07-2017, 10:22 AM   #10
Ole Don
Ole Don's Avatar
On a 57 type distributor, the wire inside the dizzy is held with a clip, then the wire is held by a smaller clip on the same part. Because the vacuum advance moves really often the wire failed, but the insulation held firm. A real bugger to find.
Ole Don is offline   Reply With Quote
Old 12-07-2017, 10:39 AM   #11
Ol' Ron
Ol' Ron's Avatar
Learn sumpin every day, till they throw dirt on ya. Another good reason to go electronic.
Old 12-07-2017, 10:45 AM   #12
BUBBAS IGNITION
Common Ron , there is NO reason to go electronic on a flathead !!!, or fuel injected , or 12 volt?????
[email protected]
Old 12-07-2017, 10:47 AM   #13
BUBBAS IGNITION
Yep this one ran and tested good on the tester UNTIL you applied vacuum to the diaphrahm then the lights on the machine went out !!!!
[email protected]
Old 12-07-2017, 11:04 AM   #14
Ross F-1
Ross F-1's Avatar
Many, many years ago I had a British car that would start and idle great, but sputter as soon as I tried to drive off. Drove me crazy trying to find the problem. It also had the wire under the points plate, and someone had replaced one of the screws holding the points down with one a little longer. That screw had cut into the wire and whenever the advance got to XX degrees, it would short out.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 12-09-2017, 09:37 AM   #15
rick r
rick r's Avatar
Agree with O'l Ron
rick r is offline   Reply With Quote
