Old 12-04-2017, 09:34 PM   #1
psogden
Default Ringing sound in engine
Lately, I have heard what can best be described as a ringing sound coming from my 59 AB engine in my 46 Mercury. It is not a chirping sound--like from a belt. It sounds kind of like high pitched bells ringing. This isn't evident at idle but always happens when engine is revved or on a load. I've oiled my generator bearing & fan. Any ideas?
psogden is offline   Reply With Quote
Old 12-04-2017, 09:36 PM   #2
Crankster
Crankster's Avatar
Default Re: Ringing sound in engine
Well, we are entering the Holiday Season.
(Sorry, couldn't resist)
Crankster is offline   Reply With Quote
Old 12-04-2017, 10:32 PM   #3
Binx
Check the wear of the piston and condition of leather on the piston in the distributor. If the piston is loose it will vibrate in the bore and make a ringing sound.
Lonnie
Binx is offline   Reply With Quote
Old 12-04-2017, 10:37 PM   #4
fordor41
fordor41's Avatar
loose bolt in flywheel?
fordor41 is offline   Reply With Quote
Old 12-04-2017, 11:06 PM   #5
Lawson Cox
Lawson Cox's Avatar
Tube in fuel pump stand, that push rod goes through, has come loose and is bouncing up and down on the cam shaft. At least that was my jingle bells.
Old 12-04-2017, 11:25 PM   #6
Talkwrench
Talkwrench's Avatar
We are not talking detonation here are we, you said under load? Not too far advanced on your timing.. ? Sounds like pebbles shaking in a can ..
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 12-04-2017, 11:37 PM   #7
Brian
Brian's Avatar
That is what sprang to my mind too....but there are some interesting possibilities being put forward. I particularly like Lawson's 'jingle bells'. So hard to diagnose these problems via a keyboard.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 12-05-2017, 11:14 AM   #8
TagMan
"...........a ringing sound coming from my 59 AB engine"
Your cell phone isn't missing, is it ?
TagMan is offline   Reply With Quote
Old 12-05-2017, 03:35 PM   #9
mfirth
I was once told about a valve seat coming out of the block and making a ringing sound...take it 4 what it's worth. The guy who told me seems to be honest.
Also, starter drive could be bumping the ring gear..????
mfirth is offline   Reply With Quote
Old 12-05-2017, 03:47 PM   #10
supereal
supereal's Avatar
One of the best ways to locate an odd engine sound is to use a length of small hose, such as for vacuum, and hold one end to your ear while you move the other end of the hose to different locations, The higher the pitch of a sound, the more difficult in finding the source. It is also a safer approach to working on a running engine.
supereal is offline   Reply With Quote
Old 12-05-2017, 09:33 PM   #11
psogden
Appreciate everybody replying. Some good ideas for me to follow up on. Thanks.
Old 12-05-2017, 10:00 PM   #12
Bill OH
I have had the timing gear give a ringing sound in an 8ba. Tapped the oil filter return line into the top of the timing gear cover and the ringing stopped.
Bill OH is offline   Reply With Quote
Old 12-06-2017, 10:16 AM   #13
estout81
Try running without generator.
estout81 is offline   Reply With Quote
Old 12-06-2017, 07:44 PM   #14
psogden
Continued thanks for ideas.
Old 09-11-2018, 02:06 PM   #15
psogden
Finally got around to further investigation. Lawson Cox (see his post below) nailed it. The sleeve inside the fuel pump stand had come loose and was making contact with the pump rod.
