Old 05-20-2017, 05:46 AM   #1
V8Germany
V8Germany's Avatar
Default Dome light 1936 Fordor
Hi community,
The dome light doesn't work (haven't checked the bulb yet). :-)
Just general... is there a switch to turn it on, can't find one at
the ceiling or does the light switch on with a door opening ?
Yeah I know... stupid question, I confess it it easier to ask
the experts than reading through the manual with a dictionary
on my knees.
Happy Weekend!
Bernd
V8Germany is offline   Reply With Quote
Old 05-20-2017, 06:07 AM   #2
Mart
Mart's Avatar
Default Re: Dome light 1936 Fordor
Is there a switch in the door pillar?
Mart
Old 05-20-2017, 06:22 AM   #3
V8Germany
V8Germany's Avatar
I looked it up but NO.... I assume that former owner put a new ceiling in and
side panels and but did not reconnect the light or put the
switch back in.
Right between the B pillar and the ceiling I can feel something that seems
to be a lose cable :-(
Probably something to sort out later.
Appreciate your help.
Bernd
Old 05-20-2017, 09:39 AM   #4
Terry,OH
Terry,OH's Avatar
On your Avatar??? & not a Coupe?? Switch is in the middle of the upper part of the passenger side (RH) B pillar. you may be able to feel where the switch should be if the backing for the upholstery has the hole in it. I suggest you get the V8 Club restoration book, on p.46 is a photo.
Old 05-20-2017, 10:09 AM   #5
JSeery
JSeery's Avatar
The routing diagrams are not exact, but might give you the basic location.
File Type: jpg Flathead_Electrical_wirediagram1936car.jpg (92.7 KB, 24 views)
Old 05-20-2017, 03:47 PM   #6
Royal Ryser
On my 36 tudor, fairly stock, the switch is on the light fixture itself. It is a pull down -push up knob that screws into the fixture.
Royal Ryser is offline   Reply With Quote
Old 05-28-2017, 09:48 AM   #7
Obsolete Jim
Obsolete Jim's Avatar
Easier fix might be to use a Dome light from a Coupe (35 or 36) which has the switch built into the assembly. Not factory, but practical.
Obsolete Jim
Obsolete Jim is offline   Reply With Quote
