#1 |
A few months ago I had the privilege of inheriting this 48' from my great uncle (my Grandfathers brother). My uncle has always been a collector of fine automobiles. It's a beautiful car and a great driver. It's a real privilege to be the next caretaker of this car. I thought you all might enjoy a few pictures of it.
#2 |
Very nice example!
Always a great privilege to be the next family caretaker and have the complete history of the car. |
#3 |
Very nice, please enjoy you new Ford!
#4 |
Very nice, 48's are neat!
#5 |
Beautiful car and great pictures. Looks like there's not too much to be done. BTW, the other cars in your garage look pretty awesome as well!!!
#6 |
GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
#7 |
That's a beauty!!
#8 | |
The 48' doesn't need much. Everything works but the radio. It drives great. Fires right up ! Thanks! |
#9 |
Very nice car, but it has the G series 6 cylinder which isnt original to a 48
#10 |
Enjoy it and drive the hell out of it. It's no good sitting in the garage.
The sign of a good craftsman is how well they cover up their mistakes. |
#11 |
#12 |
Specifications of the 2 very different Six Cylinder Ford Motors.
The “G” series engine was still very Ford-like. The “H” series engine was almost a copy of a Plymouth, Pontiac, or Studebaker six. If you can, refer, for example, to pages 210-213 in the “Green Bible” (Chassis Parts and Accessories Catalogue, Passenger Cars 1928 thru 1948 and Trucks 1928 thru 1947). Both were L-Head engines and both used timing gears rather than the timing chain used on the Plymouth and Pontiac sixes. “G” Series Distributor on front of engine Oil pump on front main bearing cap like V-8 60 and 9N tractor Mushroom-foot valves Split valve guides retained by horse shoe clip “H” Series Distributor on side of engine Oil pump on right side of engine below exhaust manifold Valves with split keepers Pressed-in valve guides Specifications “G” Series Bore: 3.3 Stroke: 4.4 Displacement: 226.0 Compression Ratio: 6.70 Brake Horsepower: 90@3300 “H” Series Bore: 3.3 Stroke: 4.4 Displacement: 226.0 Compression Ratio: 6.80 Brake Horsepower: 95@3300 |
#13 |
The following information was copy/pasted from the VanPelt website. This and other sites I used when rebuilding my motor (42 G six cylinder) is where I came to the conclusion I did.
The original G Series engine was used in Ford Special, Ford Deluxe, and Ford Super Deluxe passenger cars. It was also used in Ford Commercial and Truck models (except COE - cab over engine). The engine was rated at 90hp at 3300 rpm. The first two years (1941 to 42) models used Holley single barrel carburetors (1GA-9510-A). The 1946 to 47 models used the Holley single barrel carburetor (5GA-9510-A). In late September 1947 Ford changed the six cylinder engine to the H Series which had the same bore/stroke and displacement of the earlier G Series engine from 1941 to 1947. The newer engine had slightly higher compression and the new "Loadamatic" type distributor. 1951 was the last production year for the flathead six as Ford introduced the new over-head valve six for 1952. Other changes include larger main bearing journals, new rotor type oil pump, newer Holley carburetor (8HA-9510-A), new water pump, and one-piece valve guides. In early 1950 the camshaft was changed. Otherwise, the basic engine remained similar to the G Series design of '41 to '47. The block and head were of cast iron with the valves located in the block. The newer version gained 5hp over the G Series. The engine is easily distinguished from the G Series by distributor location....the new Loadamatic distributor is mounted to the left side of the cylinder block near the middle of the engine. |
#14 |
Now with all that said, I have a firm belief Ford used up old stock until it ran out. That being said I wish to re-cant my statement the motor may not be original. My 42 has a tag on the seat that says its was from a run made for the 41. If thats an early 48 it just may be possible (my opinion) that motor is original. My apologies to elturo, that is one fine looking car and the family tie just makes it that much more special.
#15 |
That is one very nice looking car, even if if has "more" doors than Two. |
#16 |
G6 Ford Engine on display at the Ford V8 Foundation Museum at Auburn, Indiana. |
#17 |
Nice car...... Congrats!!!!.....as others have said the family tie is priceless. Enjoy!!!...... Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver…RIP |
#18 |
Woah! A kissin' cousin to Old Henry for sure. Beautiful car! Hope you have as much fun with it as I do with Old Henry, also a family heirloom. These cars love the open road.
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
#19 |
Nice car with plenty of room, enjoy.
#20 | |
( ) but I agree with you beautiful car. Fordoors really do not get the accolades they deserve. In NZ in hot rodding circles they are known as a "ford house", lots of door and windows....big enough to live in or at least hold a party.GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" Last edited by Graeme / New Zealand; 04-28-2017 at 07:10 PM. |
