Old 04-09-2017, 08:35 PM   #1
goodoldvic
goodoldvic's Avatar
Default 1929 Tudor body on 1931 frame
Is this a hard swap barring any repair I find I need to make? My frame is sagging on the passenger side behind the rear motor mount causing a hood alignment problem on the pass side. My driver side door hangs 1/2 low on the belt line alignment. No rust outs on the car body or frame. I have an opportunity to buy a '31 frame that has the emergency brake and service brake cross shafts in place and the running board brackets are there. FWIW my e-brake is to the front of the gearshift and my cars a driver. I've read Mr. Pluckers frame study and got some education like the moving of a frame to body mount, front crossmember height at the frame rails and changes to holes ect. I'll take any advise/hints the community can share. Apologies if a similar thread exists I tried the search feature. Thanx
goodoldvic is offline   Reply With Quote
Old 04-09-2017, 08:41 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: 1929 Tudor body on 1931 frame
Wouldn't it be much easier to just straighten the 29 frame?
Old 04-09-2017, 08:55 PM   #3
goodoldvic
goodoldvic's Avatar
Thanx for you interest and insight Mr. Wesenberg.The fame has a welded repair of a tear on the frame side rail to the rear of the pass motor mount and the top rail is buckled. It's not pretty. I'm looking for insight on swapping the frame not repairing mine.
Old 04-09-2017, 09:54 PM   #4
Larry Jenkins
Problems in the radiator mounting pads?
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 04-09-2017, 10:20 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
You have read Steve's study so you know there is going to be some work involved as it is not just a simple swap, but it has been done. As to, "is this a hard swap..." well that depends on your skill set. Might not be hard but rather, time consuming changing things out.
Old 04-10-2017, 01:55 AM   #6
Beauford
You will need at least either a 28-29 front crossmember or 1/4 pad (a lot cheaper) under the radiator to get proper alignment. The frame for 28-29 had a raised mounting area on the front crossmember giving the radiator correct height. I may be wrong but I thought I may be in that situation at one time and researched myself.
Beauford is offline   Reply With Quote
Old 04-10-2017, 04:07 AM   #7
Charlie Stephens
Be sure to work with the DMV since the serial number is on the frame. If you are not careful they will want to register your car as a "31 because that is what their book says. Shouldn't be a problem if you start early to make sure it isn't.
Charlie Stephens
Old 04-10-2017, 11:39 AM   #8
denniskliesen
denniskliesen's Avatar
I wouldn't worry about DMV because they can't see where the frame serial number is when the car is assembled. I've had several old cars serial number verified and they always go by the engine number when they can't find a frame number.
denniskliesen is offline   Reply With Quote
Old 04-10-2017, 03:10 PM   #9
redmodelt
redmodelt's Avatar
Yes but the next person might when the car is sold to a state that would require a frame number check on car from out of state.
Old 04-10-2017, 11:30 PM   #10
WestCoast
type westcotts auto in your search box, when you get to there site click on tech and you will go to the frame section, a lot of model a info there
WestCoast is offline   Reply With Quote
Old 04-11-2017, 08:00 AM   #11
goodoldvic
goodoldvic's Avatar
Thanx to all who posted, the Westcott site has some good diagrams.
