Old 03-23-2017, 07:02 PM   #1
Floridian Flathead
Red face speedometer cable lubrrication '37 ford
Hello:
Looks like I can use some help here. My speedo cable has been yelling at me so I disconnected lt from tranny and gauge. Pulling from the gauge end, the inner cable will rotate but will not pull out. All loading has been removed from outer cable. Have I done anything wrong yet?
Thanks,
Rich
Floridian Flathead is offline   Reply With Quote
Old 03-23-2017, 07:21 PM   #2
1934
1934's Avatar
Default Re: speedometer cable lubrrication '37 ford
Hold the cable up at the gauge end and spray some WD40, or similar lubricant, in the speedo cable housing. This worked for me on my '34. Good luck.
Doug.
1934 is offline   Reply With Quote
Old 03-23-2017, 09:08 PM   #3
WestCoast
some speedo cables come out from the transmission end
WestCoast is offline   Reply With Quote
Old 03-24-2017, 05:54 PM   #4
Floridian Flathead
Thanks to all who replied, got it out today.
Old 03-24-2017, 06:58 PM   #5
37 Coupe
37 Coupe's Avatar
The best stuff I have ever used is Sil Glyde that NAPA sells. It has many other uses but it is one handy tube to have around and has a very wide temperature range. Slather the entire cable with it.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 03-24-2017, 07:28 PM   #6
Lawson Cox
Lawson Cox's Avatar
Doug.
WD40 is not a lubricant. WD stands for water dispersant. 40th try.
Old 03-24-2017, 08:24 PM   #7
grovesmr
No one believes me either.
grovesmr is offline   Reply With Quote
Old 03-25-2017, 06:02 AM   #8
1934
1934's Avatar
I realize that WD40 is not a lubricant and I see that I didn't phrase my response very well. I should have said; WD40 or a lubricant. My bad! I just wanted to point out that WD40 worked for me when I had a similar isssue with my speedo cable.
Doug.
