#1 |
I am putting in new head studs and am looking for a schematic that tells the proper bolt length for the proper hole. Has any one come across one of these for a 24 stud motor or is this a trial and error type deal?
#2 |
What year engine?
#3 |
And, what cylinder heads are you using??
#4 |
It's a 59a block guessing the year of 1946, the heads are stock.
#5 |
Guessing that you've bought a set of studs, put the head on a table top.
Place the studs where you think they would fit. Look for equal length at the top. Karl |
#6 |
#7 |
great idea, Karl.....m_w, are you planning to run a filter canister??....need longer studs for that??...Mike
#8 |
no Mike I am not planning on it, I went with the standard ARP studs for the stock cast heads.
