Old 03-11-2017, 01:34 AM   #1
1949mercury
1949mercury's Avatar
Default 12v coil ?
What 12v coil with built in resister do I need to convert my 49 flathead?
1949mercury is offline   Reply With Quote
Old 03-11-2017, 05:22 AM   #2
Charlie ny
Default Re: 12v coil ?
49merc,
NAPA IC 64 or the Bosch 00012. The Bosch has a funky aluminum case if
you are into funky.
Charlie ny
Charlie ny is offline   Reply With Quote
Old 03-11-2017, 08:26 AM   #3
TomT/Williamsburg
TomT/Williamsburg's Avatar
You might also check with Bubba's Ignition. I use his could and they have worked well for me ....
TomT/Williamsburg is offline   Reply With Quote
Old 03-11-2017, 12:37 PM   #4
1949mercury
I don't like funky haha. I got a 12v coil and stater solenoid from Vintage Auto garage but I think i burnt it up. Put a meter on it and Ohm 200 +- was 3.4 & 20k center coil was 8.4. Trying to get my motor to start on the frame 2 yrs ago I had it dynoed and broke in it ran good. I also got a napa number off of a tractor site ic145b ? Anyone heard of that one?
Old 03-11-2017, 08:16 PM   #5
1949mercury
I went to Napa and the ic64 is now the ic14.
Anyone know the OHM reading it's supposed to be?
Old 03-11-2017, 08:24 PM   #6
JSeery
JSeery's Avatar
You would have to have the spec's on that specific coil, but in general as shown. IF you are not using a ballast resistor you want something in the 4 ohm range in the coil itself.
All I can find with a quick search is: NAPA IC-14 Echlin 3.25 ohms primary resistance
Old 03-11-2017, 09:02 PM   #7
1949mercury
Thanks. That's what mine is measuring. So I guess I didn't over heat it.
Old 03-11-2017, 09:09 PM   #8
Drbrown
Drbrown's Avatar
JSeery: Thanks for posting that testing diagram.
I have a 12 volt coil from both Bubba and Charlie NY (a Bosch Blue). IMHO they are both top quality for professional services and parts. My two both test at about 3.4 ohms.
Drbrown is offline   Reply With Quote
