Old 02-25-2017, 11:55 AM   #1
Art Newland
Art Newland's Avatar
Default Looking for a little info 49 Pickup
I'm looking to add some company for my 30 coupe, and have takin' a liking to a 49 1/2 ton. Are the seats adjustable? Leg room for 6ft 2?
Art Newland is offline   Reply With Quote
Old 02-25-2017, 01:13 PM   #2
1948F-1Pickup
1948F-1Pickup's Avatar
Default Re: Looking for a little info 49 Pickup
I've got the same truck basically. The seat does slide.
Mine is all the way back against the gas tank. I'm 5'8"
and it's comfortable. The guy I got it from was around
6' 2" or so and he was comfortable.
If you wanted a bit more legroom than having the seat
all the way back, you'd probably have to delete the
gas tank and move it to under the bed.
Headroom may or may not be an issue. I have about
6" to the headliner.
1948F-1Pickup is offline   Reply With Quote
Old 02-25-2017, 01:17 PM   #3
V8ER
I'm 6'4", and I was comfortable.
V8ER is offline   Reply With Quote
Old 02-25-2017, 01:36 PM   #4
SofaKing
SofaKing's Avatar
This is not specific to the 49 but old pick-ups in general, the seat back is too vertical and the angle is made worse by sliding the seat bottom aft. It may affect your comfort level.
SofaKing is offline   Reply With Quote
Old 02-25-2017, 10:36 PM   #5
Art Newland
Thanks all.
Old 02-25-2017, 10:51 PM   #6
37Benny
37Benny's Avatar
So you want a Model A and a Early Ford V8 truck? am I starting to rub off on you? lol..back in high school I use to run around with a guy that had a 49 pick up, and it had room, I am six,one in cowboy boots. benny
1937 Ford 1 1/2 ton Deluxe Panel (78-80D)
1937 Ford Deluxe 4dr Touring Sdn (78-73D)
1928 Ford Model A Tudor Sdn (55-A)
1928 Ford Model A TBD
MTFCI & AACA
Tacoma Model T Club
Tyee Old Car Club
Gallopin Gertie Model A Club
37Benny is offline   Reply With Quote
Old 02-25-2017, 11:51 PM   #7
Art Newland
You can't have them all Benny. 8^)
Old 02-26-2017, 06:40 AM   #8
41LjH
41LjH's Avatar
If you are comfortable in your 30 coupe you should have no problems with the 49.
I am 6'-0" and things are a little tight in my 41. I agree with the comment about the seat and find the size of the steering wheel is also a factor.
3 pedals, 3 gears, no valve-covers..
Now THAT is a hot rod !!
https://www.youtube.com/watch?v=ZmwwB34vxJE
41LjH is offline   Reply With Quote
Old 02-26-2017, 02:36 PM   #9
Art Newland
some pics
Old 02-26-2017, 03:39 PM   #10
Art Newland
Doesn't appear to be any special group dedicated to the F1 series. Is there another website you'd recommend? A buying guide of some kind would be helpful.
Old 02-26-2017, 05:38 PM   #11
FortyNiner
FortyNiner's Avatar
While many have made the tank swap for 'more' seat room, I'm not convinced on the value. Considering that the stock seat is fairly vertical and already uses every bit of the avaiable cab space, changing might shift the geometry but can't create new space. I'm 6'2" and don't have any head or confort issues. Your fit may vary.
On the sites, take a look at the 48-56 forum at Ford Truck Enthusiasts (ford-trucks.com). Good group, very accepting, and active.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 02-26-2017, 06:12 PM   #12
1948F-1Pickup
I'm on Ford Truck Enthusiasts occasionally. I don't
think it's as good as this forum, even though there isn't
a dedicated F-1 section here.
The first time I saw that bed tank design it was in the
Classic Haulers catalog...... They're now pretty much
handled by Mid-Fifties.
http://midfifty.com/item.php?INV_ID=...ectangle--door
There's a few variations out there on this theme, including one where a section of the bed panel flips up, allowing access to the gas fill neck, etc.
I can't direct you exactly because it's not on my "pending projects" list, but some pretty
clever stuff is available.
Old 02-26-2017, 07:28 PM   #13
mercman from oz
mercman from oz's Avatar
Nice looking 1949 Pick-up.
Old 02-26-2017, 09:33 PM   #14
Bruce Koukalaka
Droool!
Bruce Koukalaka is offline   Reply With Quote
Old 02-26-2017, 10:21 PM   #15
Dick Webber
There is a 48-49-50-51 52 F-1 thru F-8 page on Facebook
Dick Webber is offline   Reply With Quote
Old 02-27-2017, 12:12 PM   #16
Art Newland
I'll check this out. Here's the link;
https://www.facebook.com/VintageFordTruckClub/
Old 02-27-2017, 05:13 PM   #17
elmangle
elmangle's Avatar
I'm 6' even and with the seat fully back on my '49 I'm comfortable, but the bigger problem is that the gas pedal is too vertical so I end up just operating it with my toe.
elmangle is offline   Reply With Quote
Old 02-27-2017, 05:30 PM   #18
Art Newland
I owned a 65 F-100 that I installed a 302 in. I replaced the accelerator pedal with something else, might have been from the same donor car. Was more of a full-floating style that operated with a cable. Maybe something like that would work better in the '49? Model A's have a funny kind of gas pedal, not very comfortable either, but you get used to it.
Old 02-28-2017, 09:15 AM   #19
mtflat
mtflat's Avatar
There are a few of us here that focus on trucks. In my opinion, you'll get better info here than some other forums because there you have to sort out the real stuff from the junk that gets posted by guys who are in competition for post counts.
You got honest info on this thread...
Just beware, you buy one and others will follow it home!
mtflat is offline   Reply With Quote
Old 02-28-2017, 12:02 PM   #20
Art Newland
So then, where are the normal rust-out spots to look for?
