Old 11-25-2010, 09:12 AM   #1
Ron/IA
Default Steering Column Support
I have a friend with a leaky steering column support at the gas tank on his 1930 Model A Tudor. I know there is a fix which puts the column mount on the dash; thus relieving the tank from the stress of the column.
I have not been able to locate this information (I did have it on my old computer, but it crashed).
Can anyone help me out?
Thanks,
Ron/IA
1929 Fordor Steelback
Hawk A Model A Ford Club
http://hawkamodelaclub.org/
Ron/IA is offline   Reply With Quote
Old 11-25-2010, 09:31 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Steering Column Support
Ron, are you of the opinion that if the column is removed from the tank bracket that the leak will stop?
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 11-25-2010, 09:45 AM   #3
Ron/IA
Brent - No, the leak will have to be fixed (he is in the process now). I just wanted to show my friend how this problem could be avoided in the future, and then let him decide.
Anyone been able to find the info yet?
It will be much appreciated.
Ron/IA
Old 11-25-2010, 10:01 AM   #4
gpits68
gpits68's Avatar
i think that late 31 model A's had a steering colomn support mounted off of the dash rail,therefore not putting stress on the gas tank.he could repair the leak,then add the 31 support with the original one not actually supporting the column.
gpits68 is offline   Reply With Quote
Old 11-25-2010, 10:02 AM   #5
1931 flamingo
1931 flamingo's Avatar
Use the later 31 steering column suppot (available from the vendors) and it mounts up under the dash panel (Ibelieve to existing holes, may have to use spacer washers). Others more knowlegable may chime in. U could also do a search as this has been discussed in detail before.
Paul in CT
Old 11-25-2010, 10:15 AM   #6
john in illinois
john in illinois's Avatar
On a 30 the 31 support bolts on using two of the under dash bolts-no spacer needed. Also,don't use the bottom support as the two together can cause more problems. loosen the steering box and then tighten the 31 support.Leave the bottom bracket rubber cushion out and there won't be any strain on the tank.
john in illinois is offline   Reply With Quote
Old 11-25-2010, 10:17 AM   #7
BRENT in 10-uh-C
Hey Ron, I think THIS is what you are looking for.
BRENT in 10-uh-C
Old 11-25-2010, 10:36 AM   #8
Jazzjr
Jazzjr's Avatar
Here is a Link from Mac's for the Bracket for a 1930-31. Mac's has a sale on this weekend, 10% off everything in their Catalog with the Code below
Use Promo Code "TURKEY10". Offer Ends November 30th, 2010
http://macsautoparts.com/model-a-ste...0R3CHL1096376/
Jazzjr is offline   Reply With Quote
Old 11-25-2010, 08:11 PM   #9
Bill Steiner
I used two washers to space mine down a little. I did not want it to touch the old support. Bill
Bill Steiner is offline   Reply With Quote
Old 11-25-2010, 08:16 PM   #10
gpits68
gpits68's Avatar
can the additional support be used on a 28-29?
Old 11-25-2010, 08:53 PM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
Someone put a late support on my 29 Tudor. It seems to fit OK, but I'll probably remove it someday when I restore the car.
Old 11-25-2010, 09:44 PM   #12
LeRoycoupe/N.Y.
YES-can be used on 28-29
LeRoycoupe/N.Y. is offline   Reply With Quote
Old 11-25-2010, 09:48 PM   #13
mrtexas
mrtexas's Avatar
Buy an original bracket. They are much better than the repros. Ebay has them all the time:
http://cgi.ebay.com/ebaymotors/ford-...#ht_500wt_1182
mrtexas is offline   Reply With Quote
Old 11-25-2010, 10:21 PM   #14
Brian SATX
Brian SATX's Avatar
You can add it to the 28-29 without drilling any extra holes in the car. Someone posted here before with pictures of how to do it. You take a samll plate that matches the holes behind the dashrail. Make some more hoels to match the drop and then you are good to go. I will see if I have it in my files.
Brian SATX
Brian SATX is offline   Reply With Quote
Old 11-25-2010, 11:24 PM   #15
LeRoycoupe/N.Y.
It posted by JoeWay under next post (Steering Column Mount)
Old 11-25-2010, 11:35 PM   #16
Ron/IA
All - Yes, the information you have supplied is exactly what I was looking for (and what I remembered after seeing said info).
I will make copies of the pictures, and part information.
Thanks,
Ron/IA
