Old 01-27-2017, 08:21 AM   #1
Dyna
Dyna's Avatar
Default Carb gasket wicking gas
I recently had my Holley 94 double barrel carb rebuilt. Seems to be working fine. I have noticed that the upper gasket is damp with gas, more toward the front above the bowl than the rear of the carb. I have made sure that the bolts are tight. Anyone seen this? Is the a fix? The shop that did the rebuild has been doing these carbs for years. I will be in touch with them. Anyone want to weigh in.
Dyna is offline   Reply With Quote
Old 01-27-2017, 08:31 AM   #2
trainguy
trainguy's Avatar
Default Re: Carb gasket wicking gas
Float setting may be a bit high.
trainguy is offline   Reply With Quote
Old 01-27-2017, 08:44 AM   #3
37 Cab
37 Cab's Avatar
Could be the top was not tightened evenly at some point in time warping the top.
Tommy
37 Cab is offline   Reply With Quote
Old 01-27-2017, 09:41 AM   #4
19Fordy
19Fordy's Avatar
After you find out why you have such an abundance of gasolene, apply a thin layer of this to both sides of your gasket. Buy the tube.
http://www.aircraftspruce.com/catalo...ezturnlube.php
Old 01-27-2017, 10:01 AM   #5
john in illinois
john in illinois's Avatar
Fuel lube is good for radiator and gas cap gaskets also. Makes them easier to turn.
John
john in illinois is offline   Reply With Quote
