Old 01-24-2017, 11:33 AM   #1
DD931
DD931's Avatar
Default FoMoCo logo - When used?
I'm trying to date an ignition switch I want to sell. I think it belongs to 51/52 F-1/2/3. It is marked on the back with FoMoCo. Does anyone know when Ford started using that logo?
Thanks!!
DD931 is offline   Reply With Quote
Old 01-24-2017, 12:03 PM   #2
Bob C
Default Re: FoMoCo logo - When used?
Did a search and found this.
On 11/20/1948, a U.S. federal trademark registration was filed for FOMOCO. This trademark is owned by Ford Motor Company,
One American Road
Dearborn, MI 48126. The USPTO has given the FOMOCO trademark serial number of 71569147.
Bob
Old 01-24-2017, 12:08 PM   #3
1942deluxe
1942deluxe's Avatar
Be aware a service part from the 50's may have that logo and not be correct if you are having your vehicle judged. I had vent glass I used on my 47 business coupe with an 11A part number that had the FoMoCo "bugs". They fit fine but would not be correct as the bugs should say "Ford".
1942deluxe is online now   Reply With Quote
Old 01-24-2017, 12:27 PM   #4
blucar
blucar's Avatar
I worked part time in a Ford dealership in eastern Idaho in 1948. Emblems on the Ford trucks changed from Ford script to Ford block letters, Parts started to be boxed/identified as FOMCO.. Automobiles stayed with the Ford script on the emblems.
Bill.... 36 5 win cpe
Old 01-24-2017, 01:27 PM   #5
rotorwrench
rotorwrench's Avatar
Henry died in 1947. A lot of changes were made after that event that would not have happened otherwise.
Old 01-24-2017, 01:46 PM   #6
Barry-ct
Barry-ct's Avatar
The "FOMOCO" label is back in use. I was at the Ct. camping show Sunday and peeked under the hood of a 2017 Transit van. The engine ( South African made ) and the vehicle spec label both had Fomoco in large and small block letters.
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 01-24-2017, 05:19 PM   #7
DD931
DD931's Avatar
Thanks to all for your replies!! I'm narrowing down my search for the year(s) of my ignition switch!!
Old 01-24-2017, 05:28 PM   #8
1942deluxe
1942deluxe's Avatar
Does it have an engineering # on it?
Old 01-24-2017, 07:06 PM   #9
Don Rogers
Don Rogers's Avatar
While researching Ford radiator hose markings a while back, I discovered that Ford started to use the FoMoCo script marking on radiator hoses in October 1949.
Don Rogers is offline   Reply With Quote
Old 01-25-2017, 10:50 AM   #10
DD931
DD931's Avatar
Other than the terminal IDs on the back, the only letters/numbers on it are "B1" on the side of the casting.
Old 01-25-2017, 10:52 AM   #11
DD931
DD931's Avatar
I'll post some pics when I get a minute to work on it.
Old 01-25-2017, 12:15 PM   #12
DavidG
DavidG's Avatar
Don,
That's consistent with the beginning of the block letter era where Ford stopped using the script on North American vehicles (and elsewhere to varying degrees).
Years later Ford hired a firm specializing in designing logos for corporations and it turned out that the firm they picked was a conscientious one as their report to the Company stated that their research concluded that Ford in the scripted oval was the second-most recognized trademark/logo in the world (after Coca-Cola) and that they could not hope to improve on that. The result was a return to the oval and script, albeit slightly modified with shorter tails on the letters and a shorter, taller oval, on Ford vehicles, dealer signage, etc.
