Old 11-21-2010, 12:11 PM   #1
Jack Innes
Jack Innes's Avatar
Default Power steering - 1954
Hello, I have a 54 Ford & would like to convert to power steering. What years of p.s. systems will adapt easily to the 54? I am sure many have done this before. Alternately, does annyone have a spare p.s. setup for sale? Thank you
Jack Innes is offline   Reply With Quote
Old 11-21-2010, 12:54 PM   #2
Gerry
Gerry's Avatar
Default Re: Power steering - 1954
There is an article in Y Block magazine this past issue about installing a modern ford power steering box in a 56 Ford. But if you are not a mechanic and the motor is still in it's not a job for a novice. Might also plan if you found a set up complete might be 1000.00 to 1,500.00 it depends on who, and what shape it's in. Good luck Gerry
Gerry is offline   Reply With Quote
Old 11-21-2010, 02:00 PM   #3
JeffB2
JeffB2's Avatar
Check out this site: www.webrodder.com look to the right for All Tech Articles there is a lot of info on a '55 Courier build including the power steering step by step with pics that should answer all your questions.
JeffB2 is offline   Reply With Quote
Old 11-21-2010, 02:42 PM   #4
Ole Don
Ole Don's Avatar
There are serval that will bolt on. A reworked integral PS unit made to fit a 55 Chev can be made to work, but only if you have an automtic trans. The clutch likage wont fit with that unit on. There are rack and pinion systems available, but they work best with a different engine. With a Y block, the oil pump, oil filter, clutch linage and steering head all need the same space. The stock systems are still out there, dont giv eup. It took me years to find mine.
Ole Don is offline   Reply With Quote
Old 11-21-2010, 10:02 PM   #5
parklane
parklane's Avatar
Granada/Monarch P/S system is almost identical to a 54-56 setup. Just needs a minor change at the idler arm location.
If brains were wire, some couldn't short circuit a firefly
parklane is offline   Reply With Quote
Old 11-22-2010, 12:56 AM   #6
Gerry
Gerry's Avatar
Parklane I remember seeing a write up on this. Mabe at the Y Block Forever site. Was writen up in CVA I think Writen by the late Dick Cohen, will have to look for it, that was a much easier and much less expensive set up. Gerry
Old 11-22-2010, 09:33 PM   #7
parklane
parklane's Avatar
Ya, all the work is in the linkage.............nothing to do with the steering box. Just find yourself a donor car, and have at it.
Old 11-22-2010, 10:37 PM   #8
paul2748
paul2748's Avatar
Late 60's Cougar. Almost a bolt in, two of three bolt holes line up. At least for a 55/56 it does.
Old 11-23-2010, 10:26 AM   #9
Noswal
I used the Granada on my '54. Almost a bolt in. Easy to do if you are mechanically minded at all.
Noswal is offline   Reply With Quote
Old 11-26-2010, 10:32 AM   #10
oldskool
oldskool's Avatar
im interested in any info on that granada p/s swap for my 54 merc w/manual steering,like what years granadas and whats involved any one done this..thanks al
oldskool is offline   Reply With Quote
Old 11-26-2010, 03:42 PM   #11
parklane
parklane's Avatar
I believe that all years are the same.
Old 12-09-2010, 05:55 PM   #12
ctfortner
ctfortner's Avatar
I ran across this the other day...must be fairly new
https://www.borgeson.com/xcart/produ...cat=117&page=1
Here is some food for thought on the granada swap
ctfortner is offline   Reply With Quote
Old 02-15-2015, 01:52 AM   #13
stacks38
I just finished installing the Borgeson unit in my 54 sedan. It is a great box and small enough to let me retain the column shift. The results are fantastic. I used to have to chase the car all over the road because of a sloppy box but now it is easy to keep straight and the turning is very easy. I highly recommend them although their coupler uses a set screw that rubs the inside of the steering column. It must be shortened so that it is almost flush with the coupler.
stacks38 is offline   Reply With Quote
Old 02-15-2015, 06:54 AM   #14
Big Red 51
Big Red 51's Avatar
Smile Re: Power steering - 1954
Jack, Why not just get a stock 1954 setup and do an easy install, no modifications. They are out there and correct and work just fine.
Don
Big Red 51 is offline   Reply With Quote
Old 02-17-2015, 03:01 AM   #15
stacks38
The stock 54 power steering is a ram assist. I wanted a fresh box and frankly the ram assist has its problems. Trust me, installing the Borgeson kit is the way to go.
Old 02-17-2015, 03:56 PM   #16
JeffB2
JeffB2's Avatar
Well,four years later and we have never heard back from Ol' Jack.
Old 02-17-2015, 09:51 PM   #17
nascardave
Hi, If anyone needs the granada steering instructions , I have them. They are the ones that Dick Cohen passed around.
Just email me [email protected]
nascardave is offline   Reply With Quote
Old 02-19-2015, 11:47 AM   #18
ctfortner
ctfortner's Avatar
Stacks, can you share any information and photos on what you did for column supports (dash and floor) and did you do anything different for the large firewall hole? What pump did you end up running, ford, borgeson or saginaw?
I have the borgeson box mounted and I have a late 60's Pontiac tilt column I am shortening to mate with mine. You may have ended up with the factory dash mount for the column but mine will take some fab work as the column is thicker in diameter than the stock one. I am thinking I need some floor support and I am planning to fill the factory firewall hole and cutout whats needed for the new column install and figure out a way to seal it up good.
Old 03-15-2015, 09:54 PM   #19
stacks38
I was able to use the original tin at the firewall but did buy a new rubber seal from C&G Ford Parts. Having a larger diameter column will work in your favor as the original Ford one will not fit over the Borgeson box.
I am using a Volvo electric pump to run my power steering. This is because it is somewhat trick and also I could not find a place to mount a pump on my 223 inline 6 engine. The electric pump works great.
Old 03-16-2015, 09:00 AM   #20
scicala
scicala's Avatar
Another one of those posts where the original question asker did so over 4 years ago and hasn't been heard from since. Everyone is talking to themselves again.
Sal
