Old 11-09-2016, 01:21 PM   #1
Floyd
Default 32 roadster windshield seal
Simple question. Does the rubber seal at the bottom of the windshield frame lay against the outside of the ridge on the cowl or up against the inside ledge? Pictures I have seen are not clear. Inside looks better, outside allows opening windshield.
Thanks
Floyd is offline   Reply With Quote
Old 11-09-2016, 01:30 PM   #2
DavidG
DavidG's Avatar
Default Re: 32 roadster windshield seal
Outside of the ridge as the windshield was designed to open. Further, if the rubber weatherstrip were located inside of the ridge it would be useless in preventing water intrusion while driving in the rain.
Old 11-09-2016, 01:43 PM   #3
woodiewagon46
As wind and rain press against it it helps make the seal.
woodiewagon46 is offline   Reply With Quote
