Old 10-19-2016, 07:11 AM   #1
Steve T.
Default Looking for a solution
I have a 1946 Ford 1 ton , with the lower front mount distributor and the fan belt hits the bail wire that holds the cap in place. Is this a common thing ?(I wouldn't think so) I'll try just about anything.
Thanks Steve T.
Steve T. is offline   Reply With Quote
Old 10-19-2016, 10:19 AM   #2
38bill
38bill's Avatar
Default Re: Looking for a solution
A photo would help as pulleys and thing may have been changed over the years. If nothing else you could switch to a crab cap and ditch the double cap and bail wire.
38bill is offline   Reply With Quote
Old 10-19-2016, 10:40 AM   #3
rotorwrench
rotorwrench's Avatar
38bill's solution would be the easiest since you would only have to get the cap and the two clips to hold it plus a new set of ignition leads.There might be some extreme wear in the fan parts that allow it to droop. Parts are available for the 21A type fan hub assembly.
Old 10-19-2016, 12:27 PM   #4
GB SISSON
GB SISSON's Avatar
Thanks Steve T.
I have a minor collection of '46-'47 tonners and I welcome you to this small club. I run the crab cap on everything here just like these guys said. People here are very helpful. And we like pictures!
Old 10-19-2016, 01:30 PM   #5
Ross F-1
Ross F-1's Avatar
Do you have the correct fan belt? Would one a little longer or shorter change the belt position enough that it would clear?
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
