Old 07-16-2016, 08:19 PM   #1
29 A-MAN
Default 50 Ford running poor at higher rpms....
Hi everyone. I have a 50 flathead that's. 30 over but otherwise stock with a model 94 carb. Idles pretty good for the most part but falls on its face and misses badly when you start accelerating. If you Crack the throttle it will review but basically not drivable....trend a different coil first with no luck. I am running an electric fuelike pump also. Any suggestions on where to start???
Any help is greatly appreciated!
29 A-MAN is offline   Reply With Quote
