Old 05-27-2016, 05:23 PM   #1
Old Redneck
Old Redneck's Avatar
Send a message via AIM to Old Redneck Send a message via Yahoo to Old Redneck
Default Model number for electric fuel pump 6&12 volts
I need to put a electric fuel pump on my 35 pickup which is 12 volts then the electric fuel pump quit working so I will half to replace it also and it 6 volts. I forget the model numbers and brand to order. Any help I could use. I can't remember anything anymore.I need to order two maybe 3. Thanks
Old Redneck is offline   Reply With Quote
Old 05-27-2016, 05:33 PM   #2
Joe Immler
Default Re: Model number for electric fuel pump 6&12 volts
Not sure from your post what you are looking for. If it is a 6 volt pump I installed an Airtex years ago and am happy with it.
Airtex electric pump E8902 Available at most auto parts stores.
I have an on/off switch and use only when needed.
Joe Immler is offline   Reply With Quote
Old 05-27-2016, 05:43 PM   #3
Old Redneck
That the one I need for my 39 6 volts. My 35 has been converted to 12 volts years ago. I want to put a electric fuel pump on it also.
Old 05-27-2016, 06:19 PM   #4
Old Henry
Old Henry's Avatar
For 12 volt: Airtex E8016S. 2.5 - 4.0 psi so would need a pressure regulator. Available here: http://www.amazon.com/Airtex-E8016S-.../dp/B000C1LW0E
Old 05-27-2016, 06:21 PM   #5
Old Redneck
I just went to Advance Auto Parts and got two pumps one 12 volts and one 6 volts. I want to thank you for your help. Cost was 90.08 for both of them including tax. Now the work begins.
Old 05-28-2016, 07:59 AM   #6
19Fordy
19Fordy's Avatar
Please post photos of the pumps you bought.
Glad you will soon be "on your way."
Old 05-28-2016, 02:07 PM   #7
jack orchard
Thanks, Prof. Henry ,The Roaming Gnome. I ordered one. You saved me a bunch of time.,...jack
Proud FNG
We fixem cars. Heap Good!
jack orchard is offline   Reply With Quote
Old 05-29-2016, 06:50 AM   #8
Old Redneck
On the 12 volts pump I only use it when the flathead vapor locks then turn it off. Its hot here today so I am going to clean and polish the 35 Pickup
Old 05-29-2016, 09:53 AM   #9
Wick
Wick's Avatar
My 41 truck is positive ground 6v will it run hooked up that way?
Wick is offline   Reply With Quote
Old 05-29-2016, 11:41 AM   #10
Joe Immler
Wick, I believe you can hook it up either way as it has a terminal marked +and-.
However, you can email the sales rep, Shane Newman. He knows old car stuff.
[email protected] That way you will have it in writing.
Old 05-29-2016, 12:15 PM   #11
Edwardrosinski
Yes
Edwardrosinski is offline   Reply With Quote
Old 05-29-2016, 03:38 PM   #12
Old Henry
Old Henry's Avatar
Yes. Just be sure to ground the positive lead on the pump and connect the negative lead to the source of your current.
Here, in my installation, the tan is the positive lead and is grounded. The black is the negative lead and is fed through a switch.
You also might want to install a small LED indicator light to remind you the pump is on if you are just using it intermittently to remind you to turn it off when you don't need it any more.
Old 05-31-2016, 05:12 AM   #13
Wick
Wick's Avatar
Thanks everyone.
