#1 |
Which mufflers have the softer sounds on a 35 PU with a rebuilt 59A and dual exhausts ?. steel pack of fiberglass, 17" or 22" and does the size of the exhaust pipes make any noticeable difference. Looking for the 1950's rumble. Also want to be able to hear the dog bark from the passenger side
Thanks
Lineman, the only dumb animal that can harness himself !! |
#2 |
A lot of people think the 1 3/4 sound the best and it is a noticeable difference.
#3 |
How big is the dog?glass packs,mellow,steel packs,not so mellow.Smithys ok ,Brockman,the best! I have both.Phil
#4 |
I'm also interested in this subject. My 59AB came with "aged" Smitty's with stock headers using the good old fashioned dual exhaust conversion kit and small pipes. Although they sound "nice" (that 50's sound) especially when one steps on the gas at lower speeds, the Smitty's are a bit loud for my personal taste. My grand kids never rode in a car like this and they are fine with it but its a bit annoying to adults especially during an extended drive.
I will be installing glass-packs and judging from posts on related threads, it sounds like Brockman's would be a good choice. Any other brands suggested ? |
#5 |
Hmmm..... I have 22" Smithys and they're too quiet. They have an arrow on them showing which direction they go, so I cut them off and turned them round. However it made no difference. All that work and welding for no improvement. Grrr.
#6 |
Fiberglass will be more muffled and muted (softer) than steel pack Longer mufflers will be more muffled and muted than shorter Fiberglass will eventually burn/blow out and get louder and harsher with time...
Daddy always said, "If yer gonna be dumb, you gotta be tough" and I'm one tough sumbitch! T5 Tech |
#7 | |
It's to insure that exhaust gasses etc. are not being blown into the open end of the internal louvers, causing early breakdown of the fiberglass packing.
#8 |
I have Smithys. Love the sound. To me it is just right.
#9 |
https://youtu.be/7gPK0ieTfDg
check this out, straight pipes!
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
#10 |
Like Phil said, go with Brockman steel packed Mellow Tones, you'll be glad you did.
#11 |
13/4 pipes with Brockman Mello tones-i have them in steel packs and the sound is very mellow --kinda just right
#12 |
Robert dick, do you have a 22 " Brockman mufflers ?.
#13 |
#14 |
I don't run mufflers. It's not loud. Just put in an equalizer pipe.
