Old 12-24-2015, 01:29 PM   #1
BNewman
Default Brumfield
I have a head on my '31 I am told is a Brumfield.
It has a small B just forward of the distributor and viewed correctly from the manifold side of the engine.
Does anyone know what compression ratio it might be?
Thanks
BNewman is offline   Reply With Quote
Old 12-24-2015, 02:36 PM   #2
JohnLaVoy
JohnLaVoy's Avatar
Default Re: Brumfield
Brumfields were 5.9, but they usually had a BF marking. There were early heads with a B only on them.
JohnLaVoy is offline   Reply With Quote
Old 12-24-2015, 08:29 PM   #3
Houdini
Houdini's Avatar
Thanks for starting this thread.
The previous owner told me he had installed a Brumfield head. I was also wondering what the compression ratio was. I thought I had read that there were different ones, starting at 5.5, then 5.9 etc.
I went out and looked at my head and on the top of the casting there is a marking with B - R, with the dash in-between the two letters.
I thought these were just heads that were machined down, but it seems like they were cast this way, based on the marking on the head being raised letters, versus stamped.
So were there different compression head ratings or just 5.9 for all the Brumfields, or were the different ratings offered by other manufacturers?
Houdini is offline   Reply With Quote
Old 12-24-2015, 08:42 PM   #4
Benson
B-F
Brumfield-Finney
Just mention his partner Finney to Larry and he has been known to get all "wound up".
5.2 (Bill Kenz told me 50 years ago that this was the compression on the "head with the large B" aka Police head, which I am still running on the Coupe.)
5.9
6.5
7.1
And almost any custom CR within reason ...
Benson is offline   Reply With Quote
Old 12-24-2015, 09:52 PM   #5
Houdini
Houdini's Avatar
I'll have to take a closer look to see if it what I thought was an R is an F.
Old 12-25-2015, 10:04 AM   #6
1931 flamingo
1931 flamingo's Avatar
Larry posts regularly on the AHOOGA message board. FWIW
Paul in CT
Old 12-25-2015, 11:36 AM   #7
Benson
Larry posted recently on Ahooga, a procedure of how to measure the head and then he could tell the compression ...
Old 12-25-2015, 08:46 PM   #8
5window
5window's Avatar
Originally Posted by Benson View Post
B-F
Brumfield-Finney
5.2
5.9
6.5
7.1
I don't know the man, but from previous postings here on the FB before he left, or perhaps, was asked to leave, it didn't take much to get him "wound up". Hope it's happier over on Ahooha.
5window is offline   Reply With Quote
Old 12-26-2015, 12:19 AM   #9
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
He is talking about producing the heads again.
Old 12-26-2015, 12:28 AM   #10
CarlG
CarlG's Avatar
That's what he said 5 years ago when I inquired.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-26-2015, 04:58 PM   #11
Giles
Giles's Avatar
Hi Bnewman - If what you are describing is a raised capital B cast into the head just north of the distributor, and nothing else, then what you have is not a Brumfield but a so-called "police" head. These were an in-period Ford option and raised the CR to, if I remember rightly, 5.6. I've used one for 15 years and it just makes my A a little livelier.
Giles is offline   Reply With Quote
Old 12-27-2015, 09:50 AM   #12
kenparker
kenparker's Avatar
here is the B-F on a Brumfield head. This head was bought in mid '90's. Currently on my 1928 pickup.
kenparker is offline   Reply With Quote
Old 12-27-2015, 10:04 AM   #13
Joop
Joop's Avatar
Police Head
Joop is offline   Reply With Quote
Old 12-27-2015, 12:25 PM   #14
FrankWest
FrankWest's Avatar
Roughly speaking how much additional HP can you get out of a 6:1 head. From a standard model A Head? Can this increased compression damage the engine?
FrankWest is offline   Reply With Quote
Old 12-27-2015, 01:19 PM   #15
Tom Wesenberg
Tom Wesenberg's Avatar
Some years ago there were dyno tests done and posted on Fordbarn. The 5.5 head added about 10 H.P. and was the best bang for the buck to increase horsepower. There wasn't too much gain using the 6.0 over the 5.5 head, as I recall.
You also need a good cam, and not one with worn lobes and tappets.
Old 12-27-2015, 01:34 PM   #16
FrankWest
FrankWest's Avatar
Thanks
Does anyone know how The compression of a model B head compares with a Model A head. Is a model A 4.5:1?
Old 12-27-2015, 01:47 PM   #17
Tom Wesenberg
Model A head is 4.2 and the B head I think is 5.2, but I hope someone correct me if I'm wrong on the B head.
Old 12-27-2015, 02:42 PM   #18
Bob C
According to Vince's site the A head is 4.22 the police head is 5.2 and the
B head is 4.6.
Bob
Old 12-27-2015, 06:18 PM   #19
Tom Wesenberg
B head is 4.6.
Bob
Yes, the "B" head is the police head for the Model A, and the Model B Ford has a large "C" on the head, and as you posted is 4.6 ratio.
Old 12-27-2015, 07:54 PM   #20
Houdini
Houdini's Avatar
I took a second look at mine and what I thought was a B-R is in fact a
B-F. It must be the glasses. (actually, it was more likely the time from reading the letters and walking back into the house to type my earlier post that changed it from an F to a R). Should have done like I do when we go to bed at night and check 4 or 5 times to make sure the house doors are locked. Now going into a room and forgetting why you did is another problem.
I believe this was also purchased in the mid 90s, around 1997, so should I assume its a 5.9. Just wondering.
