#1 |
Is the gas cut off valve supposed to have a spring in it and if so where can I purchase one. Bratton does no carry this spring. I am having a time trying to get this one to quit leaking. Charles
#2 |
Try your hardware store for many different springs.
#3 |
Have you tried to reseat the valve? I used some polishing compound and finished up with toothpaste on mine, and it sealed up fine.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole.
#4 | |
For the spring you can also cut down a longer spring and grind the cut end flat. |
#5 |
I took it apart, applied some while toothpaste and chucked the movable part in a cordless drill and spun it in the body at a low speed until polished.
