Old 11-07-2015, 12:16 AM   #1
Tubby
Default Oil Pump Gasket
Anyone know where to buy just the gasket between the oil pump and the pickup tube for a 1939 Ford v8?
Tubby is offline   Reply With Quote
Old 11-07-2015, 12:26 AM   #2
Karl Wolf
Karl Wolf's Avatar
Default Re: Oil Pump Gasket
Easy to make that, paper and a ballpeen hammer...
Or silicone
Karl
Karl Wolf is offline   Reply With Quote
Old 11-07-2015, 07:11 AM   #3
JWL
The gasket thickness controls end clearance and therefore can affect pump performance. The original gasket is not made from a plain sheet of paper. The original is a very thin sheet. I think you will have to search for a proper thickness after checking the clearance needed to allow the rotors to move freely but with minimum clearance.
JWL is offline   Reply With Quote
Old 11-07-2015, 09:46 AM   #4
oldford2
oldford2's Avatar
Jwl,
I think he is talking about the gasket from the pickup to the pump. Not the bottom plate gasket. Thickness is not critical there. JMO. John
oldford2 is offline   Reply With Quote
Old 11-07-2015, 01:34 PM   #5
JWL
I think you are absolutely RIGHT!
Old 11-07-2015, 06:17 PM   #6
Tony, NY
I have a couple partial gasket sets. If you want, I can look and you can have it.
Tony, NY is offline   Reply With Quote
Old 11-07-2015, 06:32 PM   #7
tubman
tubman's Avatar
My 1960 "Motor Manual" which covers the last of the flatheads (1953), says to use plasti-gage to check the clearance of the rotors to the end plate. The specs they quote are .0015 to .006". Sounds like you could make your own gasket, and check the clearance. If it's within specs, you should be OK.
