Old 08-19-2015, 01:01 PM   #1
JAKEFORD
Default 8n v8 tractor
This may not be the place to post this but here goes.
I have a 1950 8N and was thinking of installing my 1949 Flathead. I will need a conversion kit and was wondering what recommendations might be out there. I know several are available but have experience with none.
Does anyone have a suggestion?
JAKEFORD is offline   Reply With Quote
Old 08-19-2015, 01:47 PM   #2
48 coupe
48 coupe's Avatar
Default Re: 8n v8 tractor
That would be a funk conversion. hard to find. google funk conversion.
48 coupe is offline   Reply With Quote
Old 08-19-2015, 03:28 PM   #3
flatheadmurre
flatheadmurre's Avatar
Modern versions of the conversion kits are available.
Is it -50 something...when the steering box get better if you want to go down the road WOT...
Old 08-19-2015, 03:40 PM   #4
JSeery
JSeery's Avatar
There are several early Ford tractor sites online that I run into every once and a while. They would most likely know what you are looking for.
Old 08-19-2015, 04:09 PM   #5
Ronnie
Ronnie's Avatar
http://www.awesomehenry.com/
R
Ronnie is offline   Reply With Quote
Old 08-19-2015, 04:18 PM   #6
Johnnydidd
Johnnydidd's Avatar
I bought one from awesome henry very nice kit, never installed returned for refund after a year an half, took It back no question asked, still like new, got back 90% of price.
Johnnydidd is offline   Reply With Quote
Old 08-19-2015, 04:18 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
Cute little bugger! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 08-19-2015, 07:11 PM   #8
corvette8n
corvette8n's Avatar
Try www.ntractorclub.com click on n-board you can get lots of info from these guys
Old 08-20-2015, 01:31 PM   #9
rotorwrench
rotorwrench's Avatar
The Funk set up was well thought out. They extended the engine cover up higher so there would be no problem with fuel tank or carburetor clearance and they ran the governor off a belt. They really needed a Sherman overdrive though and most folks just relied on the old 4-speed. I think they used the H series industrial flathead 6 in most of them but they did make a couple of hundred V8 conversions too.
If the crankshaft still aligns with the front axle pivot sleeve, a person could still add an auxiliary hydraulic pump on the front for a front end loader. Might have to put some heavier duty front tires on though. It would be kind of front heavy with all that motor and stuff.
Old 08-20-2015, 02:14 PM   #10
JSeery
JSeery's Avatar
I've seen a lot of photos of them, so there has to be a lot of them around.
Old 08-21-2015, 01:07 AM   #11
mercman from oz
mercman from oz's Avatar
Here are some pictures of a Flathead Ford V8 Powered Ford Tractor that is on display at the Tractor Museum at Westbury, Tasmania.
Old 08-21-2015, 10:14 AM   #12
corvette8n
corvette8n's Avatar
Why stop at 8.
Old 08-21-2015, 10:05 PM   #13
mercman from oz
That is way too cool. Any advance on 12?
