Old 08-02-2015, 12:33 PM   #1
Viroid
Default Electronic ignition
I am considering changing the ignition on my 52 Victoria to an electronic system. I am curious if those that have tried it find it to be a worthwhile upgrade. I have always felt that the ignition on the flat heads to be shakey, at best, I would hope that this will make it foolproof.
Thanks.
Viroid is offline   Reply With Quote
Old 08-02-2015, 12:38 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Electronic ignition
Go ahead and do it. No more points to fiddle with.
You will never regret it. Your stock distributor has a vacuum advance so check with Bubba' Ignition t find out which electronic ignition would be best for you.
Old 08-02-2015, 12:50 PM   #3
48 coupe
48 coupe's Avatar
It's like everyting else ,If they work there great. When they don't there junk. I have a Mallory breakerless from speedway mtrs, on my 48. The module went out of it within a few months. That's ben 20 years ago. Haven;t had any trouble sense. My car ran a lot sharper the minute I pot it in. Could have ben the old dist. wasn't right I would do it again Be sure and use the surge box or what ever they call it.
48 coupe is offline   Reply With Quote
Old 08-02-2015, 01:11 PM   #4
19Fordy
19Fordy's Avatar
Yes, the surge protector is a must. In case of a voltage spike it protects your distributor's
electronics parts.
Old 08-02-2015, 02:21 PM   #5
Kahuna
Kahuna's Avatar
Jim & 48cpe. What surge protector are you guys talking about?
I've never heard of this before, nor used one?
Thanks
Jim
Kahuna is offline   Reply With Quote
Old 08-02-2015, 03:34 PM   #6
48 coupe
48 coupe's Avatar
It's a little box about 2 by 2 in. wires [ I think ] connects in series from the hot wire to the ignition hot wire It s kind of like a resister . It just absorbs the spike in voltage from the gen. or alternator I think that is why I lost the first module I didn't have one on
Old 08-02-2015, 03:37 PM   #7
Kahuna
Kahuna's Avatar
Huh. Never knew they existed
Old 08-02-2015, 03:37 PM   #8
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Thanks
Jim
6 VOLT WITH GENERATOR MIGHT NEED ONE OF THESE :
http://mallory-ignition.com/active-power-filter.html
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 08-02-2015, 04:25 PM   #9
flatheadmurre
flatheadmurre's Avatar
You have 2 things to fight.
1. Voltage spikes that go higher then the ignition can handle.
This is solved by installing a metal oxide varistor between power in and ground.
The mov is passive until the clamping voltage is reached.
Select clamping voltage to fit aplication 6/12v.
2. Stray frequencys.
Noise coming from ignition and generators.
A choke coil lets DC current pass and filters away AC frequencys.
Noise filters for car audio is cheap
Old 08-02-2015, 04:31 PM   #10
tubman
tubman's Avatar
Bubba,
It says this is compatible with their "Unilite" distributors. Can it be used in other applications? Do you know the "pin-outs" on it?
tubman is online now   Reply With Quote
Old 08-02-2015, 07:12 PM   #11
BUBBAS IGNITION
Originally Posted by tubman View Post
Bubba,
That i dont know as a rule we dont use them but i have customers that do.
I think it is needed on any electronic unit especially if you are using a generator etc. Many generators produce some really nasty looking voltage.
A clean rebuild generator with a good quality voltage regulator might not need one at all.....
[email protected]
Old 08-02-2015, 09:38 PM   #12
Ford Freak
I have a Pertronix unit along w/their coil in my 8BA , and as Bubba says a "clean rebuilt generator and a good , quality voltage regulator ". No problems after 2 yrs. , so far .
Ford Freak is offline   Reply With Quote
Old 08-03-2015, 12:46 AM   #13
flatheadmurre
A simple capacitor at the generator calms down some of it to.
Old 08-03-2015, 01:07 AM   #14
40 Deluxe
Also change to a higher voltage output coil so you can run a larger plug gap which will improve mileage and performance. Just make sure you have good plug wires.
40 Deluxe is online now   Reply With Quote
Old 08-03-2015, 08:13 AM   #15
Ford Freak
How much more plug gap ? What is safe ?
Old 08-03-2015, 08:22 AM   #16
BUBBAS IGNITION
i DONT AGREE WITH THE LARGER PLUG GAP ON THE FLATHEADS!
Plug gap goes with the engine (not the ignition system) a low compression flathead doesnt really benefit from a wider gap. The advent of the wider gaps came with leaner air fuel mixture and emission standards.
I guess if the flathead was lean then a wider gap might help try to ignite the air fuel mixture.
However the wider gap requires that the coil put out extra voltage . Extra voltage can be hard on the plastics used in these old ignitions.
[email protected]
Old 08-03-2015, 11:29 AM   #17
Ford Freak
Ok , I understand . Thanks Bubba ! - FF
Old 08-03-2015, 12:32 PM   #18
Ol' Ron
Ol' Ron's Avatar
When Richard was doing all his ignition testing, he tried numerous plug gap settings and as Bubba says the stock works best. Especially on a low compression engine like a flathead. Max plug voltage id quite low 8-10 K on a 8.5CR.
Old 08-03-2015, 12:52 PM   #19
flatjack9
flatjack9's Avatar
When I first got my crab style electronic distributor, I opened the plug gap to .040. I continually had trouble with the caps cracking or carbon tracking. Went back to .025 gap. The engine still runs great and haven't had a cap problem in years
Old 08-03-2015, 02:45 PM   #20
Kahuna
Kahuna's Avatar
Can one of you smart guys confirm/deny my thought process:
I've always thought that the Battery was the "cushion" in the system.
In that you charge the battery and all attending connections come
from a point from the battery? No?
Maybe Jseery can explain it better?
I have been running Pertronix modules for more than 25 years, using
solid core Packard 440 wires and alternators. No troubles, and no cushioning device
Jim
