Old 07-23-2015, 03:01 PM   #1
ricklove
ricklove's Avatar
Default 1948 Tudor Sedan Hood Alignment Question
The hood on my car (and many others I've seen) is not aligned properly. The hood seems to be setting maybe 3/8" too far forward of the firewall and slightly elevated in the rear. Does anyone have step-by-step instructions on how to properly align the hood for the correct placement when closed? Many thanks!!!!!
ricklove is offline   Reply With Quote
Old 07-23-2015, 03:27 PM   #2
1942deluxe
1942deluxe's Avatar
Default Re: 1948 Tudor Sedan Hood Alignment Question
Rick, go to www.marksfordparts.com and toward the bottom of the page there is a link to an article on hood alignment he wrote for the V8 Times. Pretty well covers what you need. It's a bit counter intuitive. If you want to lower the hood you raise the hinge.
1942deluxe is online now   Reply With Quote
Old 07-23-2015, 03:33 PM   #3
ricklove
ricklove's Avatar
Many thanks!!!!!
Old 07-23-2015, 04:30 PM   #4
woodiewagon46
The article you are looking for is in the May/June 2009 issue of the V-8 Times. It covers from1941 thru 1948 Ford hoods
woodiewagon46 is offline   Reply With Quote
Old 07-24-2015, 06:14 AM   #5
George/Maine
George/Maine's Avatar
The hood on my 47 is off real bad. Its had 3 different hinges. Someone put new hole on pass side the inside one to make better. Still doesn't shut right.
It looks like the nose maybe off center some but have not loosened the nose.
The way the hood are made some maybe different seems the pass side is problem.
As the years go by and fixing the cars up not all cars have original hood.
Mine is no way original. I was told its a early 47 has 46 nose and hood not right.
One day the sun was just right and on fire wall was Sept 47 that's late to be early 47.
I may try speedway hood hinge kit.
George/Maine is offline   Reply With Quote
Old 07-24-2015, 06:39 AM   #6
George/Maine
Old 07-24-2015, 12:18 PM   #7
48 coupe
48 coupe's Avatar
Is that a 47? hmmmm thought the 47 had park lights below the headlights must be an early 47.
48 coupe is offline   Reply With Quote
Old 07-24-2015, 03:20 PM   #8
George/Maine
The car is a 1947 on cowl says Sept 47 and numbers are late in year.
Was sold as a early 47 on the bay. BUT Has a 46 nose the chrome should be down below the crease.
Anyway the hood is not original and doesn't fit correct.
Old 07-24-2015, 04:31 PM   #9
ricklove
ricklove's Avatar
Mine has that gap and sets high at the rear.
Old 07-24-2015, 05:47 PM   #10
waterboychuck
waterboychuck's Avatar
I guess Ford did whatever they wanted to back in the day. Georges 47 has 46 fender trim, parking lights and a particle 46 hood. I do not understand the 46 hood ornament with a 47 front of hood ornament. I also noticed that it does not have the stainless window surround.
I think that article does the trick for alignment though. Good Luck
The sign of a good craftsman is how well they cover up their mistakes.
waterboychuck is offline   Reply With Quote
Old 07-24-2015, 07:08 PM   #11
48 coupe
48 coupe's Avatar
Just a thought. as I recall when I put my 48 back together. there was an issue with the front end where the hood latches down. seems like I had to move the latch area back. it's ben 20 years so don't remember what I did to correct this issue. Think about it looks like the hood is just too far forward. hmmmmm.
Old 07-24-2015, 07:11 PM   #12
48 coupe
48 coupe's Avatar
can the hood slide back some????????????????
Old 07-24-2015, 09:26 PM   #13
FortyNiner
FortyNiner's Avatar
Read the article the solution is in there.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
