Old 06-07-2015, 07:52 AM   #1
krackerjack1951
krackerjack1951's Avatar
Default 49/51 merc water pumps
does any one know of water pump rebuilder of water pumps,,not skips in fla..is there an exchange vendor for about $50 or are they all increased their cost to $100 + for a $15 seal and 85 labor +shipping both ways.. all the retailers are nysterious as to what and where they send pumps..Cardone is also kind ofQuiet as to their process..TIA for info!
krackerjack1951 is offline   Reply With Quote
Old 06-07-2015, 08:02 AM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 49/51 merc water pumps
Skip actually does a little more than just replace a "$15 seal"......jeez! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-07-2015, 08:12 AM   #3
Mike51Merc
Mike51Merc's Avatar
Buy yourself a rebuild kit for around $30 plus shipping. DIY and then ask yourself how much you'd charge to do it for someone else.
Mike51Merc is offline   Reply With Quote
Old 06-07-2015, 08:23 AM   #4
CA Victoria
CA Victoria's Avatar
I just rebuilt an 8 ba pump. I wanted to do it my self for the experience. Cost of the parts for one pump was $30 + shipping. I'd say from start to finish; disassembly, media blast, replace parts was about 45 - 60 minutes.
They were not hard to do, you do need access to a press and a few shop tools. So for $70 + an afternoon in the shop you could do it your self.
I'll bet someone in the Early Ford V8 club in your area can help??? www.efv8.org
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 06-07-2015, 08:44 AM   #5
48 coupe
48 coupe's Avatar
I did the skip pumps many years ago 10 or so. they look real good , and I haven't had any trouble. seem to cool {pump ] good. no muss no fuss. Glad I did it.
48 coupe is offline   Reply With Quote
Old 06-07-2015, 08:46 AM   #6
19Fordy
19Fordy's Avatar
Hi Gary, Have you seen this on how to rebuild your pump.?
http://www.flatheadv8.org/Waterpump/pump.htm
Old 06-07-2015, 08:47 AM   #7
G.M.
The poor original and aftermarket design of the 32 to 53 Ford water pumps are very inefficient and sit in their housing slipping, spinning and stirring up more air than water. To make things worse as far as cooling early "rocket scientist" ( early stock car people) drilled holes in the small sparse impellers or cut off every other impeller blade. This reduced flow and less water was pushed out of the over flow tube and the engine ran slightly cooler because more water remained in the system. The more water in the system and the more pushed through the radiator the cooler the engine temperature. In order to force the water through the radiator the system needs a 4 lb pressure cap or Skips 3 lb valve on the overflow tube. Forced air passing through the radiator fins is also a BIG requirement to cool these engines. At 45 or 50 MPH plenty of air is provided, at very low speeds and idle on hot days the engine fans on most years is not enough and higher engine temperatures occur. Skip don't rebuild pumps to the stock configuration, he modifies them to produce almost DOUBLE the flow through the engine. The bodies are all remachined and shot blasted, a seat for the new turbine impeller is machined into the body, New hard SS shaft ground to the correct OD, new modern seal and assembled to the proper clearances for maximum flow. Every pump is tested on a water pump test machine and run for at least 5 minutes and the results posted in Skips log book. They are dried good, and prime painted ready for shipment. In almost 20 years NO ONE has ever been charged for repairs if required which is rare. If you have a problem Skip answers the phone. G.M.
www.fordcollector.com
Old 06-07-2015, 11:10 AM   #8
51504bat
51504bat's Avatar
For the record I sent my Merc pumps to Skip and I'm happy with them. I since have located this rebuilder right in town. I have never used him but have heard good things about his work. FWIW.
FRYERS EARLY FORD WATER PUMPS
514 W FERN AVE
REDLANDS, CA 92373-5143
(909) 335-1418
