Old 04-07-2015, 09:27 AM   #1
liteppie
Default Back window installation
What is the best and easiest way to install the back windows(those above the trunk) on a 1939 ford sedan?
liteppie is offline   Reply With Quote
Old 04-07-2015, 10:03 AM   #2
okiedokie
okiedokie's Avatar
Default Re: Back window installation
On my 40 I installed them with the rear glass out/down so I could reach in and out. I put a cord [1/8"?] in the slot of the rubber that goes on the flange of the opening after coating it well with liquid soap. I then set the glass up against the outside opening then pulling the cord onto the flange I slowly pulled the cord in small circles with pressure on the outside of the glass until it was totally engaged on the flange. Slapping the glass with your palm helps to center it in the opening. I used Drake rubber and ended up with a slight "rise" in one corner of each glass. I have some new Carpenter pieces which I have been told would not do that, but have not installed them yet. Not a hard job at all.
okiedokie is offline   Reply With Quote
Old 04-07-2015, 11:35 AM   #3
liteppie
Did you install the glass from the inside or outside of car?
Old 04-07-2015, 11:38 AM   #4
liteppie
Did you install glass from the inside or outside of car?
Old 04-07-2015, 11:42 AM   #5
19Fordy
19Fordy's Avatar
I then set the glass up against the outside opening......
Old 04-07-2015, 12:50 PM   #6
okiedokie
okiedokie's Avatar
As 19fordy pointed out, the glass installs from the outside.
Old 04-07-2015, 08:25 PM   #7
liteppie
I was looking at the back window opening on the '39 sedan and it appears that the inside of the opening is flat and a little larger than the outside of the opening. That would lead me to believe the glass should be held on the inside and the rubber should be pulled to the outside? Maybe that's why the glass doesn't lay flat. The '39 has two back windows. What do you think?
Old 04-07-2015, 09:46 PM   #8
okiedokie
okiedokie's Avatar
I think that you are correct and I am incorrect. The front glass installs from the outside, the rear installs from the inside. Sorry I mislead you. I just told my wife today that I don't experience anything that makes me feel 70. Now I have, sorry.
Old 04-07-2015, 09:58 PM   #9
cmbrucew
cmbrucew's Avatar
My 41 has a one piece glass which installs form the inside. I used an innertube to hold pressure, while I pulled the string from outside. One man job.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
