Old 03-22-2015, 12:22 PM   #1
Larry
Default Transmission Leak
I have a big leak on my 1937 Ford transmission. I was wondering if anyone could tell me what is involved with dropping the transmission to put new seal/gaskets in it? Thank you
Larry is offline   Reply With Quote
Old 03-22-2015, 12:54 PM   #2
DD931
DD931's Avatar
Default Re: Transmission Leak
What's leaking? Where?
DD931 is offline   Reply With Quote
Old 03-22-2015, 04:57 PM   #3
Larry
It looks like it is leaking on the top/back end of transmission. The fluid is traveling from the back down to the drain plug.
Old 03-22-2015, 05:00 PM   #4
Bored&Stroked
Bored&Stroked's Avatar
Question: Do you happen to have a lot of 'rake' on the car? (big and littles, dropped axle, etc).
Is it possible the torque tube is running at a downward angle toward the transmission . . . or is the car pretty much stock height and the torque tube angles down toward the banjo rear as Henry built it?
Old 03-22-2015, 08:37 PM   #5
Larry
Have a 2" drop, but it leaked before I dropped it.
Old 03-23-2015, 03:57 AM   #6
Talkwrench
Talkwrench's Avatar
It can leak from anywhere like the tower, the shafts, pin, the mounting gasket [depending on model] the torque tube housing and clams.. , If your oil is quite thin it can make it worse..
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 03-23-2015, 11:46 PM   #7
GEOFFNZ
Some leak from the rear around the layshaft and reverse idler shaft where they push into the housing. Geoff
GEOFFNZ is offline   Reply With Quote
