Old 03-02-2015, 03:29 AM   #1
santino2010
Default 1949 ignition key cylinder replacement help..
hello all I am gonna replace the key cylinder for the ignition but how can I remove the front bezel without damaging the dash and bezel.......
any special tools needed???
any info would be much appreciated thank you
santino2010 is offline   Reply With Quote
Old 03-02-2015, 05:42 AM   #2
big job
big job's Avatar
Default Re: 1949 ignition key cylinder replacement help..
I bet its the same as a truck, in which you push on the switch with one hand toward
you and the other hand rotate the chrome bezel left (if i remember) its spring loaded
no tools or science needed..
big job is offline   Reply With Quote
Old 03-02-2015, 07:24 AM   #3
toby
toby's Avatar
From the 1949- 1951 Shop Manual:
"The bezel must first be removed by prying it away from the panel. Be careful not to scratch the finish on the panel. The ignition switch can now be removed by turning it 1/8 turn clockwise(viewed from the driver's position) until the lugs line up with the slots in the panel and then pulling it out from the rear of the panel."
toby is offline   Reply With Quote
Old 03-02-2015, 10:14 AM   #4
DD931
DD931's Avatar
To remove the key cylinder you must locate the pin on the side of the switch housing. With the key inserted, turn to "On" position. Push the pin in and the cylinder should slide out. The pin can only be pushed in when the lock cylinder has the key in and turned to "On". I doubt you can do this without first removing the switch from the dash as described above.
DD931 is offline   Reply With Quote
