Old 03-01-2015, 05:53 PM   #1
gmcdiecast
Default Question on running wiper motor wiring.
I got a free after market wiper motor from a club member and it actually works. I will have to use a toggle switch as the motor has none. My question is how do I run the wire from the terminal box to a switch under the dash and then up to the motor. What path should the wire take.
gmcdiecast is offline   Reply With Quote
Old 03-01-2015, 06:27 PM   #2
Mitch//pa
Default Re: Question on running wiper motor wiring.
it would be helpful to know what were working on
Old 03-01-2015, 06:40 PM   #3
gmcdiecast
It is going on a 29 standard coupe.
Old 03-01-2015, 10:36 PM   #4
glenn in camino
glenn in camino's Avatar
Forget wipers on a Model A. Rainex is the answer.
glenn in camino is offline   Reply With Quote
Old 03-02-2015, 02:01 AM   #5
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
I would run it just about the same way as the vacuum line. Behind the dash, up the post, across the header.
Old 03-02-2015, 05:58 AM   #6
Mitch//pa
I agree with mike
I would also add a fuse for protection at the spot you tap for power
Old 03-02-2015, 08:20 AM   #7
barkleydave
barkleydave's Avatar
On my CCPU it does not have the org. windshield frame or at least it does not have the tube for the manual wiper. I prefer the Rainex wiper solution however have also toyed with the idea of installing a single wiper.
Would it be more correct on the truck to have the outside windshield wiper motor? How much of a pain am I getting into here?
The truck was done very well but surprised there is no evidence of a wiper being mounted on it. No holes nothing.
Thanks
barkleydave is offline   Reply With Quote
