Old 01-20-2015, 04:26 PM   #1
1929
Default boxing plates
My friend keeps telling me to box the frame of my 1929 coupe, he thinks its proper since I have the whole car apart, to make it a stronger frame even though iam not changing the stock engine. Many tell me I shouldn't do it cause Iam not changing the engine, but he thinks I should even if some modification to the engine will create higher speeds. Should I box the frame or don't waste my time and money???
1929 is offline   Reply With Quote
Old 01-20-2015, 04:37 PM   #2
George Miller
George Miller's Avatar
Default Re: boxing plates
No not need. But you should check and make sure it is not bent down by the rear motor mount. This happens most of the time on the driver side. But can happen on both sides.
They were bent originally from the rough roads back in the day.
George Miller is offline   Reply With Quote
Old 01-20-2015, 04:42 PM   #3
Big hammer
Not needed even with high compression head hot cam etc Straighten frame they can sag near rear engine mount if needed
Old 01-20-2015, 06:50 PM   #4
1929
thanks for the info, other question, is it a good idea to get the MITCHELL OVERDRIVE?
Old 01-20-2015, 08:41 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
If you want to drive faster than 45 I would use the 3.27 rear end gears or an overdrive, either the Mitchell or in a tranny change.
Old 01-20-2015, 08:57 PM   #6
Pickupman
I think you need to get a new friend. LOL
Pickupman is offline   Reply With Quote
Old 01-20-2015, 09:02 PM   #7
700rpm
700rpm's Avatar
Sorry, but your friend doesn't know what he or she is talking about.
Ray Horton, Portland, OR
Old 01-20-2015, 09:42 PM   #8
1929
can putting the boxing plates on the frame cause problems?
Old 01-20-2015, 09:51 PM   #9
Kevin in NJ
Yes boxing the frame can make putting together a factory car with the same fasteners very difficult.
Keep in mind that the factory A was designed to run 60 MPH over very poor roads one would drive at the time.
And, YES the cars were run that way for many many miles.
If you want a reliable safe easy driving car that run 60+ MPH anywhere then rebuild the car back to factory specs on the chassis.
If you want a car that makes a lot of noise, is not reliable or easy to drive then rod it.
Kevin in NJ is offline   Reply With Quote
Old 01-20-2015, 10:15 PM   #10
1929
Kevin,what about getting the dimpled box plates with numerous holes that are 2 inches or more
Old 01-20-2015, 10:34 PM   #11
Kevin in NJ
Why?
To what ends?
If the car is powered by the stock engine (will even one with a lot more HP) it needs only to be mechanically restored back to factory specs. (Not to be confused with Judging Standards correct)
Once properly restored back to the factory specs you can beat the crap out of an A and it is happy. Take it out in to the woods and drive around the stuck 4 WD things. Get all 4 wheels in the air over the hill. Then get back on the highway and run 55+ MPH all the way home for hours on end.
The next day it will spend an hour in a parade and be happy as a clam (just how happy is a clam?).
Read all the period literature about how people used and abused the A when they were 3 year old used cars. They were not babied!!!!!
So again why does the A need a boxed frame? (Hint: it is a waste of time)
Old 01-21-2015, 12:51 AM   #12
700rpm
700rpm's Avatar
The question you should be asking is, "Will it do any good?"
And the answer is "No."
Old 01-21-2015, 01:41 AM   #13
pooch
pooch's Avatar
Yes, you have to have threaded slugs to take the original bolts, but it is not necessary on under 200 Hp.
pooch is offline   Reply With Quote
Old 01-21-2015, 09:02 AM   #14
rusted
It sounds like you already have the plates to do the job and you are just waiting for someone on here to tell you that it is a good idea to do it. I don't think anyone is going to say it! If you are not going to put a 396 big block chevy in there, it is a waste of time.
rusted is offline   Reply With Quote
Old 01-21-2015, 09:13 AM   #15
George Miller
No need to do it, if you do you will have to change a lot of things that a stock A has. I run a 239 Flat head more than once with out the plates.
Here is a picture of my 1930 pickup with 1939 - 239 flathead. It was built from pieces so did not destroy a real truck. No boxing plates it is set up for a 4 cylinder also.
Old 01-21-2015, 09:14 AM   #16
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Do what you want to do, but it is not necessary to spend the time and money to box a frame with a stock engine. Hot Rodded car, yes, stock no!
Old 01-21-2015, 01:36 PM   #17
Bob Bidonde
Bob Bidonde's Avatar
The Model A's frame was designed to be flexible, so it has just the right amount of torsional stiffness. Boxing the side rails will change the stiffness of the frame and concentrate stresses where they should not be. I strongly recommend that you do not do it.
Bob Bidonde
Old 01-21-2015, 04:48 PM   #18
700rpm
700rpm's Avatar
Thanks Bob. I thought I had read/heard that before, but couldn't remember where, so I didn't cite it.
Old 01-21-2015, 04:55 PM   #19
Barry B./ Ma.
Barry B./ Ma.'s Avatar
A fellow I knew had a 46 Merc. flathead in his 30 stock roadster and he had no problems, just didn't try to burn rubber every time he drove it.
Barry B./ Ma. is offline   Reply With Quote
Old 01-21-2015, 08:06 PM   #20
1929
what about all the others that box a frame only because of a motor change, where does that stress go?
